Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 10-27-2009, 01:00 PM
scrambled is on a distinguished road
More VSD-e questions
I have finally been able to work on my plasma cutter. I have everything connected that I can think of.
But I still can't get it to move.
I am using a BOB from Candcnc, and the parallel interface board, and the 4 VSD's.
I installed the parameters in GDtool for the interface board, and I installed the jumper to disable the charge pump.
The Blue LED is on, so the drives are in the ready condition.
Using a multi-meter I can see a 5 volt change when I press the arrow keys on Mach. I see this 5 volt change on the MTA BOB from CandCNC. This MTA BOB is what connects to the Parallel interface Board.
Am I missing an drive enable or something else?
Do I need to connect anything else?
I will try to upload a picture of the wiring tonight when I get home.
Thanks for the help
Steve
Old 10-28-2009, 01:07 PM
Here are some pictures of the wiring.
Let me know what you think and/or any ideas.
Steve
ID:	92091   Click image for larger version
ID:	92092   Click image for larger version
ID:	92093   Click image for larger version
Old 10-28-2009, 02:13 PM
jalessi's Avatar
jalessi is on a distinguished road
Question
Steve,
Why are you attaching the MTA BOB to the VSDEPI?
Have you tried connecting from your computer parallel port directly to the VSDEPI?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 10-29-2009, 01:45 AM
Jeff-
I am connecting the VSD parallel interface board to the MTA because I am wanting to use the digital torch height controller that Candcnc has.
I have not tried to connect the VSD parallel interface board directly to the computer parallel port (yet), but that is probably going to hapen in a day or so if I can't figure this out.
I am thinking I need to use the pin #14, which is "Drive enable from PC." I am just not sure where it goes.
The charge pump is on pin #1, So I am not sure about this one.
Steve
Old 10-29-2009, 02:01 AM
jalessi's Avatar
Question
Steve,
Do you have the schematic handy for the MTA BOB?
Jeff...
Old 10-29-2009, 02:44 AM
Jeff-
Here is the link to the manual. This is a different version, but it is close.
http://www.candcnc.com/PDF/UBOB_Manual.pdf
Steve
Old 10-29-2009, 03:06 AM
jalessi's Avatar
Question
Steve,
What are these connected to?
See attached image.
I don't believe the VSD E common is +5volts
Old 10-29-2009, 03:10 AM
jalessi's Avatar
Question
How are you providing the charge pump signal to pin1 on the VSD parallel interface board ?
Old 10-29-2009, 03:18 AM
jalessi's Avatar
Question
Are you using the xml file for the U-Bob?
Old 10-29-2009, 03:28 AM
jalessi's Avatar
Question
Jeff...
Do you have "J3" set to pins 2-3 for common ground?
See attached diagram.
Jeff...
  #11   Ban this user!
Old 10-29-2009, 03:31 AM
jalessi's Avatar
Question
Steve,
Do you have a instant messenger?
Jeff...
  #12   Ban this user!
Old 10-29-2009, 10:08 AM
Jeff-
In your post #7- Those wires are "Common"
For the charge pump for the VSD, I installed the jumper to by-pass this. Once I get everything running, I will install it.
I will have to check the Jumper 2-3 setting. I think this is set correct, because on my multi meter I can see the +5 volts for "direction" for each axis.
Which xml file are you talking about? I set up the candcnc bob acording to the instructions, and I am using their plug-in for Mach3. This sets all the ports and pins.
I will set up a instant messenger. Do you have one you like to use?
Thnaks for the help
Steve
CNC mill questions - thrust bearings, leadscrew mounting, general questions tonofsteel DIY-CNC Router Table Machines 8 02-03-2012 04:42 PM
Brass vs Aluminium Vs Steel, questions, questions and questions... alexccmeister General Metal Working Machines 25 08-15-2011 01:40 PM
New here with questions whitehedr Benchtop Machines 17 05-25-2009 05:26 PM
AHC questions ccoleman Hardinge Lathes 1 05-29-2008 02:03 AM
Some Questions Metalcraft Open Source CNC Machine Designs 1 09-03-2006 12:08 PM
