| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
#13
| I believe you can quite easily tune drive not to fault in the first place. However, when VSDEPI & Mach3 are configured according to VSDEPI manual, un-toggling the blinking e-stop button in Mach will clear also drive faults. |
#14
| OK, so I'm an idiot... I went back over my original set up and found my logic fault. it was the e-stop set up. every thing is behaving properly now. I knew it would be something simple, that at one time I had misconstrued. I still have a few things to do to get this thing ready to go into production. spindle, lube system, limits and home switches. once I get all that arranged, I'll shoot some video of the machine under power. thanks for all your help. |
#15
YouTube- VID 00000-20100409-1054.3GPhere is a preliminary video of the motion master, I have it running pretty slow, and the flashing light in the cabinet is the driver for the 4th axis which I have to build yet, I still need to find a way to reduce jerk in the motion, and still be able to run smoothly through a lot of short segment code in 4 axis motion but two d works great. |
#17
| I think the rapids are set at about 8000mm/min, I haven't really pushed it too hard yet I was cutting the pocket in the video at 2500mm/min, I have cut air at 4000mm/min in 2d tool paths but I am going to need fairly fast machining of 3d and 4 axis production cutting pretty soon. I have ordered an analog output interface that I am going to implement because I need better smoothing than is currently available in 4x in Mach3. and I haven't been able to come up with a way to make it happen with mastercam and helical tool paths. I have worked with techn isel controllers for a long time and I have also worked with the old DOS version of wincnc either on costs me about the same money, but I have my operator set with the techno and this way I have only one interface on all my machines except my wood lathe. I will probably move mach3 to that |
#18
| Xerxes, Can I run an analog interface through the vsdepi card ? it will already provide a single source for relays, enable switching etc, I would assume that it should work easily enough to wire the analog control through pins 15 & 16. What do you think? |
#19
| This is because VSDEPI uses analog input pin as drive disable/enable control. |
#20
YouTube- motionmmach3tempst.3GPthis is a video of some actual production of parts, probably too long, running motion master at 3.5 m/min rapids 8m/min 15 deg ramp entrance pcd tool 18000 rpm cutting 3/4" mdf using mach3 tempest planner, smooth stepper and of course vsd xe drives running fanuc ac servos with encoder count only (no hall effect), 1k steps /mm resolution. Xerxes, your products are amazing! Thanks |
| Hafco Metal Master HM-52 CNC Conversion | chich2 | Vertical Mill, Lathe Project Log | 319 | 12-15-2011 05:05 AM |
| Need Help!- Siemens 810M 1720 ORD + X error (Motion Master Router) | mjhjenks | Controller & Computer Solutions | 6 | 03-02-2010 04:06 PM |
| motion master going granite | Montabelli | Hobbycnc (Products) | 0 | 09-30-2009 10:22 AM |
| Motion Master Router with AB9/260 | alexplace2001 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 08-03-2009 12:59 PM |
| Motion Master router | Jennifer | DIY-CNC Router Table Machines | 6 | 10-16-2004 11:26 AM |
