Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 08-04-2009, 10:32 AM
Xerxes's Avatar
Xerxes is on a distinguished road
Cool New drive features & software
We have been working on new interesting features for VSD-E series.
One of most important feature is a dual axis DC servo firmware (DualDC). In other words, run two indepenent DC servo axis with one drive. Or build a 4 axis machine with just 2 drives. Price per axis is unbeatable by any currently available competing product.
Also new software has been developed. One of them is DCtool for easy dual axis DC motor setup. The second is a new firmware uploader (GDflasher) that eases firmware installation to drive.
ID:	85659   Click image for larger version
Old 08-07-2009, 07:19 AM
Montabelli is on a distinguished road
how do you handle more than one encoder per drive?
Old 08-07-2009, 08:28 AM
Xerxes's Avatar
There are two encoder inputs in ENC connector. Both are hardware counters with high speed and digital filtering. Encoders can be single ended or differential.
Old 08-07-2009, 05:13 PM
Juka is on a distinguished road
Is it possible to add backlash compensation to VSD-E ?
Old 08-08-2009, 08:28 AM
Xerxes's Avatar
I haven't seen reason to implement that in drive because it's done in every controller application.
Old 08-08-2009, 08:44 AM
Xerxes's Avatar
Since the drive has two encoder inputs, it would be also possible to support dual feedback (motor + linear encoder simultaneously, but without index pulses). Anyone interested about that?
Old 08-08-2009, 11:10 AM
asuratman is on a distinguished road
Xerxes,
If 2 motors driven with 1 drive that means we should use 2 ea smaller motors or we can use the same size motors for ea drive. Thanks. Asuratman.
Old 08-08-2009, 03:26 PM
You are right, but Mach and Smooth Stepper have some problems with that.
Just need to wait a new plugin...
Old 08-08-2009, 07:03 PM
Xerxes's Avatar
Originally Posted by asuratman View Post
Xerxes,
With VSD-E DualDC you can drive 20A peak/8A cont @ 160VDC for each motor. With single DC motor the rating is 40A peak/14A cont @ 160VDC. These ratings are guaranteed with great safety margins, no need to worry about overloading drive.
Old 08-09-2009, 03:54 PM
ihavenofish is on a distinguished road
i was pondering inexpensive glass scales for a mill coversion soon. was curious if i could use thouse with your drives.
so you are saying i could use both the rotary and linear at the same time? would that basically act as a redundancy check? say a belt pulley snaps, the drive "knows" and faults?
while im here, with the current drives, can i use a linear encoder alone? im planning on those cheapie ebay c7 ball screws. i though with the linear encoder, i would have absolute position, and not have to map the screw in the controller. sound reasonable?
  #11   Ban this user!
Old 08-09-2009, 05:24 PM
Xerxes's Avatar
Linear encoder can't be used alone unless you use linear motors. So rotary encoder is stil needed for stability against backlash & limited stiffness.
Linear encoder would be used as position feedback which efficiently eliminates all backlash and screw error. Such system is used in the most accurate machines.
  #12   Ban this user!
Old 08-09-2009, 05:36 PM
so, with the drives you have for sale right now, i could not do linear encoders?
if so, when are the new ones coming, and will they cost more for the one with that feature?
thanks
Just IN- ERP Software MIE Trak 10.3 Released With Over 150 New Features MIE Solutions Product Announcements & Manufacturer News 0 04-13-2009 12:34 PM
Need Help!- Software vs floppy drive jstucken Haas Mills 7 05-28-2008 09:34 AM
Torchmate Drivers Software Features Mike@Torchmate Torchmate 7 05-20-2008 05:20 PM
Driver software. ( List the features you want ) ynneb Polls 26 08-08-2006 06:56 AM
USB Thumb Drive Software automizer General CAM Discussion 6 12-29-2005 01:14 PM
