Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
  #13   Ban this user!
Old 08-09-2009, 05:42 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Originally Posted by ihavenofish View Post
so, with the drives you have for sale right now, i could not do linear encoders?
if so, when are the new ones coming, and will they cost more for the one with that feature?
It only would require firmware upgrade to support this feature in currently available drive. I'm haven't decided if I'm going to implement this in firmware (and GDtool).
  #14   Ban this user!
Old 08-09-2009, 06:26 PM
ihavenofish is on a distinguished road
ah, so i can just buy drives when i need them, and know that if you do add that feature, it will work with mine.
merci.
  #15   Ban this user!
Old 08-12-2009, 07:11 AM
noname is on a distinguished road
Tero, it would be great if that option is implemented.
Having a double closed loop will put the drive in a different category. It will also bring the possibility of having good dynamics and precision in low cost systems. Probably this is the only thing missing in the topology of your
control loop, where you have already the three usual nested loops.
Usually, industrial cnc machines close the position loop on the controller and
the velocity loop on the drive. To be able to do that you need a controller with this capability (e.g. Heidenhain, Bosch-Rexroth, Siemens,...)
Low cost cnc controllers (e.g. Mach) don't have this ability. So, having
the drive doing that will be a great benefit. There are also simple 1 or 2
axis precision applications that will benefit from this option.
In fact is the main reason that is keeping me from buying some of your drives (which I really like, specially the ability to standardize on a hardware
that solves a lot of motion control applications in a lab environment).
Having an EtherCAT interface will be the icing on the cake and will also
open a lot of industrial applications to your drives
jose
  #16   Ban this user!
Old 08-12-2009, 05:01 PM
Xerxes's Avatar
Now it is official. Enjoy!
http://www.granitedevices.fi/index.p...e-dualdc-servo
  #17   Ban this user!
Old 08-12-2009, 06:22 PM
wiat, what? i thought this was a new drive for the dual servo. crazy man
now if you could do dual brushless, youd save me a bit of money!
the dual encoder for one motor thing is a separate (potential) update though right?
  #18   Ban this user!
Old 08-13-2009, 05:50 AM
asuratman is on a distinguished road
Xerxes,
Is your dual driver only for DC servo motor? Thanks. Asuratman.
  #19   Ban this user!
Old 08-13-2009, 06:27 AM
Xerxes's Avatar
Making 2 axis AC drive would require significantly more complex & expensive hardware. I'm not probably doing it.
Jose,
Thanks for wise thoughts. I might do experiments with linear encoders support one day.
EtherCAT seems interesting but thousands pages of complex specifications are absolutely not tempting :P
  #20   Ban this user!
Old 06-26-2011, 05:14 AM
LUCKY13 is on a distinguished road
Linear encoder can't be used alone unless you use linear motors. So rotary encoder is stil needed for stability against backlash & limited stiffness.
Linear encoder would be used as position feedback which efficiently eliminates all backlash and screw error. Such system is used in the most accurate machines.
This would be very helpfull to have. I would be changing out my drives and putting these in if they could do this.
Jess
Just IN- ERP Software MIE Trak 10.3 Released With Over 150 New Features MIE Solutions Product Announcements & Manufacturer News 0 04-13-2009 11:34 AM
Need Help!- Software vs floppy drive jstucken Haas Mills 7 05-28-2008 08:34 AM
Torchmate Drivers Software Features Mike@Torchmate Torchmate 7 05-20-2008 04:20 PM
Driver software. ( List the features you want ) ynneb Polls 26 08-08-2006 05:56 AM
USB Thumb Drive Software automizer General CAM Discussion 6 12-29-2005 12:14 PM
