Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 06-10-2009, 03:42 PM
gavztheouch is on a distinguished road
Galvanic Isolation, What does it mean for my power supply
After researching potential power supplies for my Granite device drivers, I discovered my DC power source needs to be Galvanicly Isolated to work with Teros drives.
What do I need to do, or check to make sure my current power supply has Galvanic Isolation?
Gav
Old 06-10-2009, 03:47 PM
Al_The_Man's Avatar
It is another way of saying Electrically Isolated.
I am assuming that in this case it probably means that the P.S. should be electrically isolated from ground?
Old 06-10-2009, 04:12 PM
H.O H.O is offline
H.O is on a distinguished road
It means that there is no electrical connection between the primary and secondary sides of the power supply. Variacs are typical examples of transformers that (usually) doesn't have galvanic isolation between the input and output - not good in this case.
Old 06-10-2009, 04:38 PM
So, is it rare to find a power supply that does not have Galvanic Isolation?
Old 06-10-2009, 04:58 PM
Al_The_Man's Avatar
It is rare to find a power supply that is not isolated.
The reason is that in most parts of the world, the primary supply is common to earth ground.
With the primary and secondary isolated it allows the option of allowing the DC to float or the DC common to be connected to earth ground if it was so wished.
Your PC power supply is an example of this, it is isolated from the mains supply, but the DC common is then referenced to earth ground.
Old 06-20-2009, 01:01 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Correct.
Typical isolated power supplies are:
-Most of regulated switching power supplies
-Transformers (with isolated primary and secondary)
-Safety isolation transformers
-PC power supply is isolated but not having floating output (which is Ok, too)
Typical non-isolated (non-safe) supplies are:
-Direct rectification of mains AC voltage
-Autotransformer
-Variacs
Old 06-22-2009, 01:57 PM
I took a video of the supply this afternoon to hopefully see if anyone might be able to identify what type of transformer I have? Its the big black lump at the start of the video. It looks like the wires come from the transformer, pass through a rectifiying diode, then into the big capacitor.
Old 06-22-2009, 02:11 PM
Al_The_Man's Avatar
It is hard to say conclusively, a pause on the transformer label would have helped, but I would say there is a 99.9% chance that is an Isolation transformer.
It looks like a standard DC supply of that vintage.
The main issue of a transformer being isolated is primarily one of safety rather than functionality.
If it were a non-isolated type and the correct steps were taken to confirm the connections, it is still possible to use it, it would just be that the secondary of the transformer would be referenced to ground.
Old 06-22-2009, 02:31 PM
Xerxes's Avatar
Yes but if you insert wall plug in wrong orientation (50% chance at least with european plug) then you get mains AC voltage as ground reference which would be very dangerous.
To confirm if its isolated: disconnect all wires from it and measure ohms between primary and secondary windings. If it shows infinite ohms, it is isolating type.
Transformer info http://www.allaboutcircuits.com/vol_2/chpt_9/5.html
Old 06-22-2009, 02:47 PM
Al_The_Man's Avatar
As I pointed out, it is one of safety rather than functionality.
How'd you supply your power supply? cnczane DIY-CNC Router Table Machines 12 08-28-2011 06:13 AM
Power Supply HELP!!!!! ronald44 General Electronics Discussion 2 05-19-2007 11:07 PM
More power from switching power supply R.thayer General Electronics Discussion 4 03-10-2007 08:03 PM
PCB Trace Isolation - Minimum Track and Isolation ahoodlum General Electronics Discussion 11 09-26-2006 12:02 AM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 03:56 PM
