Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 06-02-2009, 01:21 AM
scrambled is on a distinguished road
x axis problems
I am not sure where the problem is occuring, but for some reason my 2 x axis motors spin at different rates when I either press the jog button in Mach 3 or try to run some simple G-code.
anyone have any ideas where so start looking? here is a list of stuff I have already tried
-copied all of the parameters in the GDTool to both drives. Everything is set the same
-In Mach 3 I made sure the motor tuning section both were set the same
-In Mach 3 the X and A are slaved together
-Checked all the connections
both servos are 1125 in oz motors, with 5 to 1 Thompson Duratrue planetary gearboxes
Us Digital encoders with 1250 CPR
both servos are running off of a 1000 w 80 vdc power supply
Is it possible that the slower spinning servo is loosing steps?
Thanks for the help
Steve
Old 06-02-2009, 12:27 PM
Xerxes's Avatar
Xerxes is on a distinguished road
That is possible. Do slower motor change if you switch motor & encoder cables between drives?
Here is a firmware upgrade (pre-release) to VSD-E that enhances encoder noise filtering. Remember to backup drive settings and restore them after upgrade.
Old 06-02-2009, 08:24 PM
radiantheat is on a distinguished road
SOS
I was having pretty bad comm errors also, could not connect , had problems with startup mode , etc. so i tried the 204 firmware update. Now it all updated fine , but i just get a blinking green signal no matter how i set in3 and in4 . ? how do I reset ?
I can still reconnect in spishell , get status (40 errors) and readencoder.
I repeated flash job several times with different laptops , active usb ext cable , ferrite on usb cable , all other noise sources off.
help.
Old 06-03-2009, 02:06 AM
Xerxes's Avatar
radiantheat, during upgrade all drive settings are reset to factory defaults. You just need to configure all settings again like you did on very first time you got the dirive (unless you saved settings to file before upgrade).
Old 06-04-2009, 02:08 AM
Tero-
I flashed all 4 of my drives, it appears that everything is working.
Old 06-04-2009, 02:42 AM
asuratman is on a distinguished road
Hi scrambled,
Can you give us your machine picture for future reference! Thanks.
Old 06-09-2009, 08:14 AM
asuratman-
I have not taken many pictures lately because my shop is such a mess right now
Here is link of my build, it has a lot of pictures in it.
My cnc table
and here is another link
Wiring differential encoder
If you want a better picture of something, just let me know.
Thanks for the help
Steve
Z axis problems on X3 Thorpydo Benchtop Machines 11 05-03-2009 05:04 PM
help please 3 axis problems capital Fanuc 4 09-20-2007 10:55 AM
4th Axis Problems Syncrude Fadal 6 07-09-2007 10:02 AM
A Axis problems d-moncrief Haas Mills 2 07-05-2007 06:29 PM
Z axis problems Gregor Machine Problems, Solutions , Wireless DNC, serial port 0 04-25-2003 06:23 AM
