| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
I am wiring my differential encoder and I have a question about which resistor to use. According to the manual-- For long cable lengths (beyond 3 meters), it is may be necessary to terminate differential pairs with 120 Ohm resistors (connected from A+ to A-, B+ to B- etc). A 10 nF capacitor can be connected in series with termination resistor to reduce encoder current consumption. Terminators can be soldered inside D-Sub connector housing or connect them externally to EXT connector. My local Radio Shack only has 100 Ohm and 150 Ohm resistors. Which of these should I use, or do I have to order a 120 Ohm resistor? Is it ok to use ceramic disk capacitors ? thanks Steve |
| What make of encoder specifies this? Usually the differential driver used is RS422/RS485 which is good for 4000ft. If you really want to go ahead with it, 150 should work out OK. It is not that critical an application. I have never seen this in all the differential types I have used. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Al- The encoder is an E5 1250 CPR from Us Digital. Here is the link. http://usdigital.com/products/encode...5/#description Do you think this is not needed? I am just trying to make sure I am not going to have noise problems. Thanks Steve |
| I have never used US digital, But I have installed many many differential encoders and not had a problem so far, I would try without the r/c first, you can always add it if you find it necessary. Al.
| Al-the-man--- Tero- While I was flashing my servo drives, I discovered that two of my encoders have either failed, stopped working, or I let the smoke out. The Specs for the USdigital encoders are here. It is a 14 page pdf file. http://usdigital.com/assets/general/...atasheet_1.pdf These two encoders are at the farthest point from the servo drives. I ordered 40 foot encoder cables, and I only trimmed about 2 feet from these two axis. When I tried to monitor the encoder using GDtool, I only get a 0 for the encoder count. So far I have tried moving the encoder cables and that did not help. I also plugged encoders mounted on other motors to the cables of the non working encoders, and I could read the non mounted encoders. So I am thinking the wiring is ok. Tomorrow I am going to remove the encoder from the motor and remount it and see if that helps. I am also going to try to discover what part went bad by mixing two encoders and trying to get 1 reading. Any ideas on what to do or not to do? So far I have not added any resistors or caps, so that is not the problem Steve |
| Steve, Sometimes encoder outputs bad signal or nothing if its little bit incorrectly aligned to optical disk. You may want to try adjusting readhead's position and test again. I would also add termination to 40 foot cable. 100-150 ohm resistors between A&B + and - outputs at drive end should be enough. |
| I've found the US Digital encoders go together in a pretty foolproof manner. There isn't any real adjustment to the readhead, not on the ones I have used anyway (including E5). I would try using a real short wire on the encoder to see if it is working with a short cable. Also check to make sure your connector is good and no pins are bent or damaged. I have had problems before with cheap connectors not making good contact if the pins are even the slightest bit bent. Matt |
#10
| keebler303- I checked all the connectors, and they look fine. I also made sure that the connector was fully seated in the encoders. Tero- I added the 100 ohm resistors to the y axis, and nothing changed. I also removed the encoder cable to the y axis, and there was not a mark on it. I also used a meter and checked all the wires in the cable, and everything checked out. I moved pieces and parts around, and I could not find anything bad. Now one of the x axis encoders has stopped working. So now I have three not working ![]() I am going to call US Digital tomorrow and see what they say. Is it possible that the encoders and the VSD-E's are not compatible? How can I test the encoders and not have them connected to the VSD-e??? Thanks for the help Steve |
#11
| You can check the outputs on a 'scope, alternatively if you use a meter from common to each output and turn as slow as possible you can see the transition 0-5v of each output, and the complements A, /A etc. Al.
#12
| I have used several USdigital encoders (differential & single ended) with VSD-E without problems. There are rumors about weird problems with recent USdigital encoders (search for example Geckodrive forum). If someone wants to donate problematic USdigital encoder, I would be glad to check it. BTW, don't trust GDtool encoder counter too much as it gets updated as very low priority task. I have seen it freeze sometimes. |
| modify MPG to differential encoder | Karl_T | General Electronics Discussion | 7 | 05-23-2009 01:05 PM |
| differential vs. single-ended quadrature encoder? | postvmvs | General Electronics Discussion | 3 | 04-26-2008 07:28 PM |
| Differential Encoder Signals | eloid | DIY-CNC Router Table Machines | 8 | 01-29-2008 09:05 PM |
| differential encoder signal form | Karl_T | General Electronics Discussion | 1 | 03-19-2007 10:28 AM |
| Optical Encoder Differential Line Driver | azsigns | General Electronics Discussion | 1 | 03-04-2004 04:41 AM |
