Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 05-22-2009, 04:49 AM
Johan Cnczone's Avatar
Johan Cnczone is on a distinguished road
VSD compatible ?
Is the new 160v version VSD-E compatible with Fuji ACservo motor GYS series ?
It is a 200 V AC servo with 17bit serial encoder (incremental), my concern is the encoder part only
Thank you
Old 05-25-2009, 06:30 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Hi Johan,
I'm not familiar with those particular motors but your motor is probably Ok if encoder outputs also standard quadrature signals. There is a motor compatibility chapter in VSD-E manual describing different aspects of motor matching.
Old 05-25-2009, 10:30 PM
Hi Xerses,
Thank you for your reply.
I attached some of the fuji spec sheet.
I cannot find more detailed specification for the encoder, but there is a connection diagram between the motor and fuji servo controller, maybe you can take alook and comment.
The reason I am planning to use the motors is because the motors is readily available here ( no need for importing motors from other country )
so I just need to buy the VSDs from you
"It's difficult, but it's possible"
Old 05-26-2009, 07:38 AM
Xerxes's Avatar
Wiring sheet doesn't indicate that it would have quadrature outputs in addition to serial. Perhaps installation of standard encoder is necessary to use other than Fuji drives.
CUI AMT102 are cheap and good encoders if you can fit one in there.
Need Help!- Is this interface compatible with UHU ? cnc2 Open Source Controller Boards 2 06-01-2008 06:55 PM
Is this interface compatible with UHU ? cnc2 Servo Motors and Drives 0 04-11-2008 07:16 PM
gecko compatible dgalaxy Bridgeport and Hardinge Mills 2 06-04-2006 12:28 PM
TTL Compatible controller metalhacker Open Source Controller Boards 2 05-23-2005 01:25 AM
Are CAT and BT compatible? ETNOM General Metal Working Machines 2 12-16-2004 08:08 AM
