Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 05-12-2009, 05:20 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Videos of servos/steppers in action
This is a thread where everyone is free to post their videos showing machines controlled by VSD drives in action. Here is couple from me:
This video demostrates VSD-E drives drives controlling a laser diode characterization instrument.
The video demostrates VSD-E's automatic homing function at power-up. While doing homing motion to left, drive gently detects mechanical stop of axis (no mechanical limit switches are needed). After axis end has been reached, drive continues to opposing direction and searches encoder index pulse for most precise homing.
The machine has 2 axis, both in same direction and stacked. The upper linear stage has short travel and higher mechanical precision for microscope camera movement. The lower stage (long travel) has a 150W BLDC servo motor and upper stage has a small 10W DC servo.
This is same machine as above but this video shows some operation and jogging of machine from PC.
All motion control (accel & decel ramps, velocity control, torque limiting, axis travel limiting) are done internally in VSD drives. PC sends only simple move commands to drives thru USB bus.
Comments & new videos are greatly appreciated
Old 05-12-2009, 07:27 PM
Francois 3D's Avatar
Francois 3D is on a distinguished road
Smile hello
YouTube - Servo axis homing with VSD-E drive
YouTube - Servo motor control with VSD-E
I contact you for your VSD -E drive
I make a mail in this week to ask you informations before buy it
I think it's great drives :-)
I want to install a Smooth Stepper
I contact you on the week because it's not easy for me to write in english, I need a little time :-)
I have a workshop in FRANCE, i make parts bikes with CNC Mill but I want to use servo motors for speed
Regards
François CHARLOT
my mail : CFrancoischarlot@aol.com
Old 05-13-2009, 11:26 AM
gavztheouch is on a distinguished road
Nice Idea, I tried a Youtube search a couple of weeks ago while I was researching your drives, it nice to see them working.
Old 05-13-2009, 01:51 PM
Xerxes's Avatar
Here is another one. This is a video showing fast 3D CNC milling. The servo drives used in this machine are our older drive models (VSD-A's).
The video has been recorded by one of our customers and has been published with his permission.
Old 05-13-2009, 02:31 PM
Sorry please delete this post wrong topic.
Old 10-29-2009, 03:17 PM
Xerxes's Avatar
Here is a new one. It shows a linear servo motor in action:
Old 11-22-2009, 06:34 PM
Jason3's Avatar
Jason3 is on a distinguished road
Here's a short clip of the first cut with this machine, running VSD-XE drives (80Vdc version).
Sorry it's not more exciting. The cutter is definitely not for plastics, being 4 flute and coated - but does an ok job except for the very tip leaving a bit of a mess... I'll work on something better
Best regards,
Jason
Old 11-23-2009, 05:50 AM
damae's Avatar
damae is on a distinguished road
Nice videos!
That linear servo is amazing! It'll probably be another 10 years before we can take our pick of linear servos on ebay (from decommissioned equipment). Unless new prices drop dramatically...
Jason, is your machine purpose-built for PCB routing? It looks great! Nice idea to use such huge linear rails, eliminating the need for pairs of rails and all the associated alignment!
Old 11-23-2009, 06:21 PM
Xerxes's Avatar
Very nice Jason!
Linear servo might be practical to hobbyists as linear motor is probably the easiest motor to build as DIY. It is just made out of standard magnets, iron and coil. I have built one my self and it worked.
The hardest parts are the design (there are hobbyists that have done FEM simulations and designed RC motors) and making really tight winding of coils to maximize available force.
Or maybe one could just buy the "forcer" (coils) part from some manufacturer and make magnet track as DIY to save some amount of cash.
Old 12-03-2009, 04:07 AM
Jason3's Avatar
Hi Damae, my apologies for not replying sooner! The machine wasn't built with any particular purpose in mind, the goal was high accuracy and repeatability for small parts machining. I'm very happy with it
Xerxes, thank you for your kind words!
Best regards,
Jason
  #11   Ban this user!
Old 12-09-2009, 12:32 AM
Jason3's Avatar
Smile Another video!
Here's a slightly better video of our VSD-XE powered mill. Cutting acrylic again, this time with a much more appropriate cutter!
Feedrate is 160 ipm, 1/8" single flute cutter, DOC 1/8" at 20,000 rpm.
The pulse smoothing feature in GDTool is giving us really nice smooth curves and a great finish - the edges of the shape in the third photo are quite transparent.
Best regards,
Jason
ID:	94754   Click image for larger version
ID:	94755   Click image for larger version
  #12   Ban this user!
Old 12-09-2009, 05:03 PM
Xerxes's Avatar
Thanks for the video, very cool! Your machine really seems to cut shiny edges :-)
I assume you also used brushless servos on this mill.
Servos vs Steppers? ZenOrbit Canadian Club House 1 02-05-2008 08:20 PM
Steppers vs Servos Mits Spanish CNCzone 5 03-02-2007 09:26 PM
All in one steppers and servos. J Solinger LinuxCNC (formerly EMC2) 0 09-29-2006 02:42 AM
Servos or steppers Paul in OK Commercial CNC Wood Routers 9 11-17-2005 04:11 AM
steppers vs. servos twombo Machine Problems, Solutions , Wireless DNC, serial port 10 06-10-2003 03:43 PM
