| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
#13
![]() Yes, brushless servos all round again, I'm very pleased with them. I was also struck by how quiet they are, despite being tuned very 'stiff'. Best regards, Jason |
#14
| Here's another machine running Granite Devices drives, this time VSD-E 160Vdc model. Also using the new SPS-600-126 power supply as well, with 225 watt brushless servos. Still some work to do commissioning this machine, but so far I like it very much! YouTube- DeskMC-panel.m4vBest regards, Jason Ps - wonder why the video isn't embedded this time? |
#15
| The fan grill on that part is pretty cool. Nice video.
#16
| Very Nice drives... What are the prices?.. Amazed to see the 3D carving at that speed. Regards
__________________ http://free3dscans.blogspot.com/ http://my-woodcarving.blogspot.com/ http://my-diysolarwind.blogspot.com/ |
#18
Hello Jason, I watched your video and was surprised to see that you are cutting the aluminum dry. What type of bit were you using? I have trouble with the aluminum building up on the bit unless I use some type of lubricant. WD40 works well for me but tends to make a mess. Would you mind sharing your secrets. Very nice machine. Larry |
#19
| Hi Larry, I was cutting dry, yes. It was more a matter of getting away with it by using a very light cut than anything else. It was a conservative start for the machine, I wanted the part to work first time but really feel this mill could do a lot better. It was a 1/4" 3 flute, high helix cutter, feed rate was 80 ipm and rpm was 20,000. That will probably wear the tool prematurely. The part was a bit warm afterward, so the chip load was too small - tool tables tell me I should have the feed rate at 385 ipm and 32,000 rpm. I'll give that a try and see how it goes, my guess is the tool will clog and break without coolant. Regards, Jason |
#21
| Great videos as usual, Jason! Keep up the good work. Here is another kind of VSD-E and AC servo application: http://vimeo.com/14236102 The drive is installed in enclosure as intended (connectors reaching out of box, shown at end of video). |
#22
| Two VSD-XE drives integrated in serial product as motor controllers YouTube - VSD-XE drives integrated in a stand alone product |
#24
looks like there's a photodiode on the end of the moving arm, and it's measuring how much optical power a light-source, such as an LED, is outputting in each direction. |
| Servos vs Steppers? | ZenOrbit | Canadian Club House | 1 | 02-05-2008 07:20 PM |
| Steppers vs Servos | Mits | Spanish CNCzone | 5 | 03-02-2007 08:26 PM |
| All in one steppers and servos. | J Solinger | LinuxCNC (formerly EMC2) | 0 | 09-29-2006 01:42 AM |
| Servos or steppers | Paul in OK | Commercial CNC Wood Routers | 9 | 11-17-2005 03:11 AM |
| steppers vs. servos | twombo | Machine Problems, Solutions , Wireless DNC, serial port | 10 | 06-10-2003 02:43 PM |
