| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
Now that I finally have the noise problems fixed, it is time to install some e-stop relays. Where is the best place to install them? Do i want to disconnect the AC power to the power supplies, or disconnect the 80 VDC from the power supplies to the VSD-Es. Or is there a better option? Thanks for the information Steve |
| I always switch the AC side of my power supplies, switching the DC can be hard on relay contact and can create a nice plasma arc. ![]() Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Definitely switch the AC feeding the transformer OR the AC on the secondary of the transformer, before the rectifier, if the transformer has multiple windings feeding other stuff that you won't like to turn off in an E-stop condition. You can use an auxillary contact on the relay/contactor to switch in a discharge resistor across the capacitors to dump the charge quickly. As Al says, switching the DC stresses the contacts in the relay but it also stresses the drives, when the contacts closes the drive "sees" the voltage "instantly" which may cause a very high inrush current. (Beacuse its internal capacitor is discharged). The VSD-A is a solidly built drive so I'm sure it can withstand it but it IS hard on them. Another issue with switching the DC is that the returned energy from the motors (if they were spinning when the power was cut) has no way to go except the relatively small capacitor in the drives. This will pump the voltage across said capacitors up and it may go above the rated voltage of the drive depending on your particular set-up. So, in short, switch the AC and dump the charge if you want it stop ASAP - that's my €0.02 /Henrik. |
| I agree about E-stop switch placement.
| New Machine Build- EMC2 E-stop parallel port pinout and E-stop loop | GreenLead | LinuxCNC (formerly EMC2) | 12 | 08-03-2010 01:05 PM |
| Is it time to stop using Pennies. Yes, the government should stop using Pennies. | Glidergider | Environmental & Alternate Energy | 40 | 03-26-2009 12:47 PM |
| Where do I install an emergency stop button? | alexccmeister | Stepper Motors and Drives | 36 | 04-21-2007 07:40 PM |
