| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
I am developing a custom controller for VSD-A and use STEP/DIR mode to control torque. I cannot figure out the way to monitor if VSD-A has been reset by a user in the middle of a sequence. This is required to reset the torque value in the controller to zero and re-sync drive and controller. Suppose the controller commanded some required torque (e.g. 10) and then VSD-A has been power-cycled. It starts up in zero torque and if then controller winds down the torque to zero the drive will end up producing -10 as a result. Any ideas? Thanks! |
| Ideally, I want to use SPI but this still remains undocumented as far as I can see... |
| The precision of PWM input is more than 10 bits, it's about 14 bits. Things you can try to reduce jitter: -Reduce "input multiplier" from GDtool, this way input becomes less sensitive -Replace HCPL-2531 optoisolator with faster HCPL-2631 -Use lower PWM freq to get more output resolution from µC (3 to 6kHz should be best) And about the original question: If you wish to monitor if someone resets the drive, it should be sufficient to monitor logic supply voltage as it would be the only way to reset. I sent you some guidance about SPI to email. Last edited by Xerxes; 04-14-2009 at 06:38 AM. |
I have tried and did most of the tests on 3kHz PWM already and have not noticed any difference. I will try to get a faster optoisolator and see what happens. I really want to try SPI mode control at some point. |
Hi, I saw this video (http://video.google.com/videoplay?do...92974890836012) for VSD-A fluxeon drive and I have one question for xerxes, granitedevices or anyone. I found comment for this video: AC servo turning thru a mixed mode sequence: 1) Running various speeds in velocity mode 2) Homing in position mode and positioning to 180, 90 and -360 3) Running various speeds in velocity mode 4) Homing in position mode and positioning to 180 90 and -720. My question: Is it some mistake in 3)? I think it has to be 3) Running various speeds in position mode. I say this, because running motor at low speed with encoder resolutions < 60000 is imposible in velocity mode, only in position mode with trajectory profile update every 5-10 ms. Or I am wrong? |
| When I say velocity mode, I mean velocity closed control loop. And position mode, position closed loop. So, am I right when I say that this low speed rpm on VSD-A is actually velocity mode using position control ( you give continous position commands in short time steps to achieve velocity tracking)? |
Apart from that VSD-E has a "real" velocity controller that doesn't use position information anywhere but user probalbly won't notice the difference since it will also work at infinitely low speeds. |
#10
Thanks for answering the question. If we use servo motor with 1000 ppr then the lowest angular speed that controller can measure is fs/4000. Fs is velocity control loop update frequency and let say fs=4000 Hz. Then the lowest detected speed is 1 Hz or 60 rpm and it's not infinitely low speed. Speed estimation using some interpolation or observer is only remaining possibility that I know. Does VSD-E use speed estimation? |
#11
| VSD-E control algorithm doesn't have any difficulties if speed estimation shows 0 most of time. An average is only that matters. Real minimum commandable speed is actually 0.0763 counts/sec or on 1000 ppr encoder 0.00114 rpm. |
#12
Use of averaging (filtering) reduces velocity control bandwidth by way of inserting delay in control loop. If we need fast velocity response in low speed, I'm not sure about use of averaging for speed estimate in velocity control. And again, we have to go back and use position controller for velocity control. I don't know how VSD-E works at low speed with just velocity controller. On VSD-A video I saw fast response in low speed. |
| Fanuc 6m stays in "not ready" mode | hopcycle | Fanuc | 2 | 01-30-2009 08:58 AM |
| Need Help!- "Warco GH Univ" V "Chester Lux Mill" | JQ_Quint | Benchtop Machines | 37 | 01-22-2009 11:59 AM |
| G320 "common" or "+5vdc" why do they vary? | beezerlm | Gecko Drives | 3 | 01-12-2008 05:00 PM |
| "Not Ready" at startup | christoph | Machine Problems, Solutions , Wireless DNC, serial port | 3 | 08-03-2007 09:55 PM |
| Has anyone looked at the "JET" or "Shop Fox" manual machines? | boosted | General Metal Working Machines | 12 | 03-04-2007 10:33 PM |
