Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 03-10-2009, 11:43 AM
scrambled is on a distinguished road
Servo wiring question
It is time to start to wire 1 servo to my electronics to test everything.
I purchased 1125 oz dc motors from kelinginc. It is the first servo on this page.
http://kelinginc.net/ServoMotors.html
Keling states that the white wire is +++ the Black is common (-----) and the green is ground.
When I looked through the granite devices manual this is what I found
D--- Armature -
C--- Armature +
B--- Armature +
A-- used by optional resistor
I have already soldered the small board to the DB connector, so do I just use D,C, and the FG ?
Thanks for the help
Steve
Old 03-11-2009, 10:42 AM
Anyone?????
Steve
Old 03-11-2009, 11:08 AM
Al_The_Man's Avatar
I have not used either product, but if you are hooking up a DC motor to the Granite, which I gather is a DC, BLDC & AC drive, A brushed DC motor is traditionally hooked up to the U & V of the normal U,V,W outputs.
I would expect any manual should explain the different configurations.
Old 03-11-2009, 10:33 PM
keebler303 is on a distinguished road
I think you can run a DC motor in one of two modes, but its been a while since I looked at the manual and I don't own one. Pretty sure it is all spelled out in the manual, have you read it?
Matt
Edit: Directly from the manual,
"Note: in DC motor mode B & C must we wired in parallel.
In parallel DC mode C & B and A & D must we wired in parallel."
Old 03-12-2009, 12:53 AM
keebler303-
When I got home tonight, I started going through the manual again. When I got to the chart where I found the information in my first post, there it was a small footnote below the chart. This footnoote was the information that you listed. I am not sure how I missed it.
What are the benefits of wiring the motor in either DC mode or DC parallel mode, or does it matter?
I am planning on adding the resistor to help with the dynamic breaking.
Al_the_man-
There is a chart in the manual that listed the motor types (DC, BLDC & AC drive) and in a footnote below the chart, there were additional lines of information.
Thanks for all the help
Steve
Old 03-12-2009, 02:29 AM
H.O H.O is offline
H.O is on a distinguished road
In DC Parallel mode the drive can supply more current to motor, see page 32 in the manual. Note though that if you use the parallel DC mode of the drive you can't use the regenerative break resistor.
Old 03-12-2009, 03:08 PM
Xerxes's Avatar
Xerxes is on a distinguished road
In both brush DC modes C and B must be wired parallel, this reduces drive heat dissipation. Drive will detect if outputs are not parallel and will blink some error indicator leds.
There are jump wire places in the tiny D-sub adapter PCB.
Encoders & their wiring to the UHU servo controllers cnc2 UHU Servo Controllers 67 08-11-2009 02:25 AM
Wiring servo controls (T1 QT-10) carbidecraters Mazak, Mitsubishi, Mazatrol 0 10-02-2007 07:14 PM
Wiring servo Ed Williams General Electronics Discussion 8 05-19-2006 12:17 AM
Servo Wiring Help matt General Electronics Discussion 3 04-29-2006 07:07 PM
