Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 01-11-2009, 10:09 AM
polaraligned is on a distinguished road
VSD-E HOME INPUTS
Using 3 VSD-E drives with Mach 3.
Have separate home switches for each axis.
Using CNC4PC BOB.
The Home switches normally go into the BOB and Mach 3 takes care of homing.
Can the Home inputs of the VSD-E drives do anything for me?
I don't see any clear documentation to their use.
Thank You,
Scott
Old 01-14-2009, 06:16 PM
scrambled is on a distinguished road
Scott-
Have you had any luck getting an answer to this question? I am about to start wiring my drives, and I had the same question.
Steve
Old 01-16-2009, 01:52 PM
Juka is on a distinguished road
Originally Posted by scrambled View Post
Scott-
Steve
"Home switch signals routed from VSD-E's to PC"
You can also use them homing with encoder index signal. Look also GDtool manual (page 22/26).
http://www.granitedevices.fi/assets/...epi_manual.pdf
http://granitedevices.datamappi.com/...ool_manual.pdf
Juka
Old 01-16-2009, 08:17 PM
So my home switches go to the VSD-E home inputs.
I can trigger a home search by using one of the VSD-E inputs.
How do I tell Mach 3 that the machine is homed? Is there an output to tell Mach 3?
Scott
Old 01-20-2009, 02:18 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Juka is right, connect home switch to VSD-E encoder connector pins and VSDEPI routes it to PC. There are two ways to do homing (choose only one):
1) Configure Mach to use home switch signals from VSDEPI.
2) Use drive internal automatic homing function (starts at power-up). Configured from GDtool.
Pros and cons of each method:
1)
+Mach will know when homing is done.
2)
+Can also utilize encoder index pulse for highest precision
+Can use hard stop homing (no switch needed)
+Activates optional internal position limits of drive, can't accidently drive axis out of mechanical travel
-PC will not get any information when axis is homed due to limited number of of input pins in parallel port
Old 01-20-2009, 02:31 PM
Thumbs up
1)
2)
Does "hard stop homing" mean, homing with currentlimit ? Unbelievable!
Juka
Old 01-20-2009, 03:51 PM
Xerxes's Avatar
Juka
Yes, there is independent current limit adjustment in Homing controller page of GDtool.
Old 01-20-2009, 09:20 PM
keebler303 is on a distinguished road
Smart. Is this common practice in industry? I would think it would not be terribly repeatable due to having a chip stuck somewhere or something like that.
Matt
Old 01-21-2009, 04:59 AM
Xerxes's Avatar
Matt,
I think I have seen similar feature in few other drives, too. One should set high enough limit to make it repeatable in typical situations. Limit is there just to protect machine from excessive force when touching axis end.
Old 01-21-2009, 06:54 AM
H.O H.O is offline
H.O is on a distinguished road
Nice work on the VSD-E, Xerxes!
I've used the "hard-stop" homing on the EPOS-line of intelligent servo drives from Maxon. It worked very well, I just set the limit to ~20% more than what it took to move the axis at the homing speed. This was on a rather small "clean" machine though. Just don't try hard-stop and Index ;-)
/Henrik.
  #11   Ban this user!
Old 01-21-2009, 07:24 PM
I have plenty of inputs with my second parallel port plus ModIO.
I would think I could run one of the VSD-E general purpose outputs to my break-out-board and signal to Mach that home is completed, right?
Scott
  #12   Ban this user!
Old 01-21-2009, 08:55 PM
Scott
The smoothstepper also has a relative plethora of inputs.
Matt
reading modbus inputs howling60 Mach Software (ArtSoft software) 1 04-17-2007 08:41 AM
inputs outputs sintratech Machines running Mach Software 6 04-01-2007 03:17 PM
Fadal 904-1 does not respond to inputs tigerinnovation Fadal 1 01-22-2007 06:26 PM
Inputs/Outputs UKRobotics General Electronics Discussion 13 08-02-2006 10:52 PM
Encoder output into 2 different inputs? murphy625 Servo Motors and Drives 2 03-23-2005 10:36 AM
