| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
Hi, I have just got 3 Granite VSD-E drives and have a grounding question. Here is a quote from their manual: >>>>> 7.2 Grounding Drive has two separate grounds for separate purposes which are named as GND (ground) and FG (frame ground). GND is the electrical 0V potential shared with power supplies and all connector pins labeled as "GND". Connect GND to power supply 0V terminal. FG is the ground for EMI shielding which is located in D-sub connector metal shells and D-sub connector pins labeled as "FG". FG and GND are electrically floating against each other but are connected by EMI suppression capacitor inside drive. Make sure that D-sub shells make electrical contact to enclosure metal and cable shields are connected to FG through corresponding pins or D-sub shells. >>>>> I plan on installing the drives in the same metal cabinet with my computer, BOB, power supply, etc. Just like I did on my last machine. In the past I have connected all grounds to a common point inside the metal cabinet. This point also was connected to the ground of my mains AC power. Do I really need to keep 2 separate grounds? Can I just tie FG and GND together? If I tie the drive FG to the metal enclosure, then what do I do with the mains ground for safety reasons? Thanks, Scott |
| I cannot speak for Granite devices, but generally the term Frame Ground FG refers to the part of the device that comes in contact with the outer metallic case etc that would contact the enclosure or Service grounded point when mounted. Other connections are named chassis ground, Logic Ground, Power common, and these may be isolated from the case or Frame ground, then it can be made optional as to whether these are tied to the FG. There are basically two schools of thought or practices as to whether all systems are kept isolated from each other or tied together and connected to a common ground and machine bonding point. Personnaly, I find it misleading and bad practice to call these other commons 'ground' when in fact they may not be at all at ground potential, and misleading, especially to those who are newcomers to electronics. The bottom line is, you should only have one ground point set up that bonds the service ground to all the metalic points on the machine, together with the rest of your grounded commons and shields. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| Thank you for contributing input Al! Please see figure 12 in VSD-E manual. Power supply GND (0V line) should be connected to case (FG). So, do not leave GND and FG floating. Nothing will blow if this connection is not made, but may lead to worse EMI shielding. |
| 5'x 9' CNC ground up. | gurvy | CNC Wood Router Project Log | 15 | 11-04-2008 02:15 AM |
| Need Help!- To Ground or not to Ground That is the question! | Mr.Chips | DIY-CNC Router Table Machines | 1 | 03-16-2008 04:10 PM |
| From The Ground Up | Crushmonkey | Open Source CNC Machine Designs | 2 | 09-29-2007 10:53 PM |
| Ground Up | jabuffi | Mechanical Calculations/Engineering Design | 0 | 10-14-2006 03:09 PM |
| Motor supply ground vs Logic ground? | Gashmore | General Electronics Discussion | 11 | 06-07-2005 06:21 PM |
