Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 07-24-2008, 02:53 PM
realsquash is on a distinguished road
Newbie to VSD drives, having a slight problem
I've retrofitted my knee mill to use VSD-A drives. It has differential encoders from the factory on the machine and I have wired everything up and tested one axis last night. Following the procedure in the manual from the GDtool software I am having a problem. When I turn on the high voltage supply the motor starts spinning very slowly an accelerates. I always hit the estop right away because I cannot bench test my motor/encoder setup because the encoder and motor are seperate units.
I tried reversing the polarity of the encoder in the setup, it made no difference. Tonight I will try to reverse the motor leads, who knows.
Is there a way to test that the encoder is working with the GDTool or the SPI tools? I know the encoder was good when I was running the machine on another servo drive.
Andy
*Slight* change in plans...... 6x12 CandCNC douglasco Plasma, EDM and other similar machine Project Log 10 07-30-2008 07:57 AM
Slight problem with X2... abr5 Benchtop Machines 3 06-18-2007 09:36 PM
slight improvement to the classifieds daedalus Suggestions for the CNCzone.com site. 0 09-24-2006 11:37 AM
leadscrew drives (newbie) gizmo Benchtop Machines 0 04-19-2005 08:36 AM
Slight delay but back on track, advice needed Darren_T DIY-CNC Router Table Machines 23 01-25-2004 08:50 PM
