Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 07-05-2008, 11:21 AM
enno_onne is on a distinguished road
Breakout boards and DC brushless compability
hi Xerses,
I currently using stepper motor system and want to move over to servo system.
I have done some study for servo systems for about 2 months on this forum plus somewhere else but some questions still not answered yet
I am planning to use your servo drive system with other breakout boards. Just for preparation before I bought all components, I would want to make sure everything will be going nicely.
question 1:
After I read both manuals from CNC4PC C11T BOB and your VSD-A rev.2. I couldn't find the solution how to wire them together. Is it possible to use C11T and your VSD-A? it would be great if you can show the diagram how to wire them.
question 2:
If I buy DC brushless servo with spec:
48VDC 3-phase rated 660watts and 55Amp peak.
continuous 2.1 Nm torque, peak 6.3 Nm
max 3300rpm
250lines decoder (8wire)
can your servo drive get the maximum power out of that servo motor?
Cheers mate,
Enno
Old 07-07-2008, 02:10 PM
Xerxes's Avatar
Xerxes is on a distinguished road
1. I'm sure there is people with more experience using CNC4PC boards with VSD-A than me. By specs C11T it looks suitable. Generally just connect drive's DIR- and STEP- to 0V and STEP+ and DIR+ to BOB step/dir outputs. Select BOB COM terminal to be ground (0V).
2. No. It takes 55A peak current for 6.3Nm and 18.3A for 2.1Nm. Max peak torque with VSD-A would be 1.7Nm because of 15A limit.
Old 07-26-2008, 12:54 PM
hi xerxes thanks for your response. It really took me awhile to understand what you were saying. after I did some research on the manual on both products, I start to get what you mean. hahaha
do you have any actual picture for your servo drive, servo and encoder wiring?
cheers mate
Old 07-27-2008, 02:54 PM
Xerxes's Avatar
Unfortunately currently I have no photos that could serve as a good example. I usually make crap wiring deliberately for my own drives so I could spot the hardware problems if there is any. It's funny that even then I haven't been able to lose a single encoder count or step pulse.
Australian supplier of Breakout Boards? Nigel_B Australia, New Zealand Club house 4 02-17-2008 10:32 PM
Newbie question about breakout boards airbrush Xylotex 7 12-16-2007 12:53 AM
Low cost Microcontroller development Board and Programmer , Breakout Boards ahmedrehan Product Announcements & Manufacturer News 5 11-23-2006 04:34 PM
Breakout boards DaPyro General Electronics Discussion 15 06-23-2006 02:22 PM
breakout boards Gads General Electronics Discussion 2 03-05-2006 06:39 PM
