Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
View Poll Results: Which is preferred your servo drive construction
VSD-E with external power stage 8 33.33%
Miniaturized control card plugged onto external power stage 6 25.00%
Monolithic design on single PCB 8 33.33%
Other, please specify 2 8.33%
Voters: 24. You may not vote on this poll
  #25   Ban this user!
Old 08-01-2008, 07:11 AM
hunserv is on a distinguished road
Hi, I'd have some questions.
-I sadly see on yor site, that VSD-A is no longer produced. does it mean that some new is coming out soon?
-Within this planned modular design, are you planning a powerstage which supports regenerating to supply?
-Will the new design have the same PID algorithm as previous ones?
-Is there any reference where we could see which exact PID scheme it uses? (hopefully not the "textbook" basic one, but some more advanced, as differential term acting on feedback signal only, etc...)
-Are you planning some more features, e.g. making real-time motor-load outputs (I asked it earlier)
Thanks,
Aks
  #26   Ban this user!
Old 08-01-2008, 12:55 PM
Xerxes's Avatar
Xerxes is on a distinguished road
-Yes, we should get VSD-E final protos on week 32 and the first production run soon after that.
-Regenerative braking "shunt regulator" can be built without help of drive logic. However, one output pin could be assigned for regen brake control if needed.
-Same PID but also a PIV algorithm. I try to find time to document both well.
-Hardware doesn't have analog outputs. Digital output pins could be used to monitor conditions (follow error warning for example). SPI bus can be used for monitoring, too.
  #27   Ban this user!
Old 08-01-2008, 01:23 PM
neilw20's Avatar
neilw20 is on a distinguished road
Question Am I a little backward ?
A phase controlled SCR bridge can be made for peanuts and handle enough to blow the wiring off the wall without failing.
Ultra simple drive, no big capacitors needed. Just a few snubbers.
Do you need full 4 quadrant control, or is reverse with a switch/contactor OK?
Any comments?
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
  #28   Ban this user!
Old 08-02-2008, 01:52 PM
nicad is on a distinguished road
Originally Posted by Xerxes View Post
...Attach an lead screw to the moon and use servo motor with VSD drive to crash moon on earth near light speed. No damage to VSD will happen due to continuous current control (unless drive gets crushed by the moon).
So, at this point someone is suppose to jump in with all the numbers required to accel the moon to near lightspeed before it hits the earth, and how much energy that would require given the mass of the moon, and then congratulate Xerxes on building a drive that can output that much power.
  #29   Ban this user!
Old 08-03-2008, 08:11 AM
Xerxes's Avatar
neilw, SCR drive is Ok for turning pulleys in spindle and other raw power applications, but not for positioning servos. No enough control bandwidth.
The moon acceleration might require a few VSD's connected in parallel
  #30   Ban this user!
Old 08-03-2008, 10:26 AM
neilw20's Avatar
Red face Gone adrift..
Xerxes..
Oops... too late here. I missed the thread (of things) Go fast IGBT's driven by IR parts. in a H-Bridge.
  #31   Ban this user!
Old 08-05-2008, 01:52 AM
SPI bus monitoring is OK, too imho, and if someone wants analog can hook a microcontroller on it
And some more questions...
-When do you think you will have time to describe these algorithms?
-What development time do you predict for the modular controllers?
I am really keen on it, I can't say enough that I was impressed by the performace/cost ratio of the VSD-A
As I see most guys here are beyond the hobby-category, (low power) but there are still few freaks like me, who need higher outputs, which are closer to the industrial grades...
  #32   Ban this user!
Old 08-05-2008, 12:33 PM
Xerxes's Avatar
I'm doing my best to get detailed block diagrams in VSD-E manual which should be ready soon.
About VSD-Core I don't have any schedule yet. There are other things to be finished first. Product release date could be within a year.
  #33   Ban this user!
Old 08-22-2008, 09:24 PM
panaceabea is on a distinguished road
xerxes did you get a chance to read my PM?
Why such high voltage? sp1nm0nkey Stepper Motors and Drives 19 12-31-2007 12:52 AM
High Torque , High Bandwidth Motor or Servo mastabib Benchtop Machines 0 09-26-2007 02:09 AM
Power supply voltage too high spoiledbrat General Electronics Discussion 8 06-13-2005 09:39 PM
PSU Voltage seems high. mnewsholme Hobbycnc (Products) 10 04-26-2005 03:26 AM
