DC bus supply voltage 24-200 Vdc
Peak output current 15.0 A (¹
Maximum stall current 10.0 A (¹
Field oriented flux vector control for higher bandwidth
Position, velocity and torque modes
Supported motors: permanent magnet DC, AC (sinusoidal)
AC servo motor phasing without hall sensors
Quadrature encoder feedback (differential line outputs)
Command inputs: step/direction pulses and serial commands via SPI bus
Fully optoisolated command I/O
Firmware field upgrades
PC software based tuning
Arbitrary ratio input command scaling and gearing
Trajectory planner with tunable velocity/acceleration limits
Acceleration and velocity feedforwards
Soft recovery from following error
Separate supply terminals for logic and high voltage
No loss of position on high voltage outage
Typical efficiency of 95% at full power
