Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 02-11-2008, 10:27 AM
Moderator
JerryFlyGuy is on a distinguished road
Connectors for pin headers
Hey guys, I received my drives last week and am finally able to start doing the work to impliment them. I can't wait to toss these steppers..
A couple questions for those who've recieved these. Does anyone have a good Digikey number for a socket or plug which would fit these headers on the drives? I'd like to fab a plug on the end of my wire from the B.O.B., rather than solder right to the pins themselves.
Also, Tero included a small bare board w/ each drive.. any idea what that is for? It looks like it's some form of a connection/interface board.. but I'm not sure what for..
Thanks guys..!
JerryFlyGuy
The more I know... the more I realize I don't
Old 02-14-2008, 03:59 AM
dar303 is on a distinguished road
Just take a look in an old PC computer, there are usually lots of different pin header contacts to reuse.
Old 02-15-2008, 04:59 AM
Xerxes's Avatar
Xerxes is on a distinguished road
I think I'll make a PDF document to explain connections and the supplied PCB. These has been asked many times
Old 02-15-2008, 09:42 AM
Moderator
Thanks Tero, that makes be feel better .. at least .... not like as much a dummy as I thought I was
Gotta get a call into Digikey yet today.. just haven't had time spit let alone to sit down and order stuff.
Btw, I've been thinking about just buying a through-hole connector w/ a 0.10" spacing and then soldering wires to the 'through-hole' pins. The putting a heat shrink tube around it all and over the end of the wire.. do you think that should work? Not like it's a item which gets pluged/un-pluged regularly..
Curious..
JerryFlyGuy
Old 02-16-2008, 08:50 AM
Xerxes's Avatar
Connection document has been uploaded to Downloads section:
http://granitedevices.fi/index.php?q=servo-drive-vsda
Old 02-17-2008, 10:32 AM
lgalla's Avatar
lgalla is on a distinguished road
[QUOTE=JerryFlyGuy;408428]Hey guys, I received my drives last week and am finally able to start doing the work to impliment them. I can't wait to toss these steppers..
Jerry what was wrong with the steppers?Also any update on the Z axis damping?
Larry
L GALILEO THE EPOXY SURFACE PLATE IS FLAT
Old 02-17-2008, 06:48 PM
Moderator
Hey Larry. The only issue w/ the steppers is I have some issue w/ lost steps once in a while. W/ the Servo's I'll elliminate this issue. The dampening kinda got side tracked due to a couple other projects. I'm building a new Z axis instead..... long story.. the short answer was that the vibration issues were to do w/ the tool extensions and collets I was using.
JerryFlyGuy
New style connectors? impact Xylotex 0 08-06-2007 03:38 PM
Motor Connectors, what to use dneisler General Electronics Discussion 3 06-11-2007 10:47 PM
DB-25 Connectors Nmbmxer General Electronics Discussion 3 10-16-2005 08:05 PM
2x5 pin headers-why? OCNC Open Source Controller Boards 3 11-12-2004 08:35 PM
Cable Connectors redbaron DIY-CNC Router Table Machines 4 01-27-2004 01:56 AM
