Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
  #193   Ban this user!
Old 06-17-2009, 03:57 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Box of first drives arrived today. I'll do final testing of new firmware and check updated documentations before making them public.
Compared to previous VSD-E model, manufacturing cost increased over 30% (more expensive components and apparently PCB assembly houses pricing change), but we are limiting sale price increase to about 10%.
Changes in hardware are:
-Rugged 200V 60A MOSFETs (instead of 100V 33A)
-24V mechanical holding brake output
-New optoisolator for serial link (goodbye to interference caused communication errors)
-Controlled dV/dt for powerstage outputs (reduced EMI noise)
-Larger HV bus bypass capacitor
-No led signals from EXT connector any more (replaced by brake output), use optical fibers instead which reduces cable mess, too
-VSD-E heatsink has now mounting holes for a standard "Half brick" heatsink (useful for passive cooling at higher power)
  #194   Ban this user!
Old 06-17-2009, 05:19 PM
gavztheouch is on a distinguished road
Great, Il take two when they're ready. How much for shipping to the UK?
  #195   Ban this user!
Old 06-18-2009, 05:55 AM
Xerxes's Avatar
"How much for shipping to the UK?"
Please send quote inquiries to sales@ email. Small package shipping to UK is typically around 20 eur.
  #196   Ban this user!
Old 07-30-2009, 08:08 AM
fahque99 is on a distinguished road
If you don't mind me asking, what kind of circuit are you using for current monitoring with this drive?
Dave.
  #197   Ban this user!
Old 07-30-2009, 09:46 AM
keebler303 is on a distinguished road
Dave.
Shunt Resistors.
  #198   Ban this user!
Old 07-30-2009, 12:04 PM
simpson36 is on a distinguished road
I notice that the Granite drives are sold by Keling. They do not post any spec though.
Would they be likely to have the new model 160V or the older ones?
Are there any suppliers yet in the US?
  #199   Ban this user!
Old 02-21-2012, 06:32 PM
M)(M is on a distinguished road
It's too bad these VSD drives are so expensive. I can get real industrial servodrives surplus for less than the price of one of these little boards. Why make the project open-source and let it grow beyond your expectations, or at least let people build their own drives so the price isn't so nuts.
  #200   Ban this user!
Old 03-11-2012, 02:40 PM
legendboy is on a distinguished road
The only "wish" I would have for a newer version would be do away with the sub-d connectors.
I am doing a retrofit using existing motor cables. These cables are about. 75" in diameter. Not ideal to use with sub-d connectors.
  #201   Ban this user!
Old 03-13-2012, 12:10 PM
Xerxes's Avatar
Thanks for the ideas! The next drive has been under active development a while and already is looking very good. Lots of great ideas from customers have been realized (including nicer power & motor connectors).
BTW, to avoid wiring to D-sub connectors (encoder etc) one can use this kind of D-Sub-breakout connected with standard D-sub data cable:
CONN INTERFACE MODULE DSUB 15 - 2315175
  #202   Ban this user!
Old 03-19-2012, 07:42 PM
Yes phoenix contact make them too but they are less then ideal depending on component layout and extra cost is fail
The subd shells I got in my install "kit" were junk too. Had to re purchase high quality ones
  #203   Ban this user!
Old 03-22-2012, 06:47 PM
Xerxes's Avatar
Very nice installation!
It is a fact that D-subs are not the most pleasant type of connector to wire (especially the high density type, normal density is much more bearable). One alternative to soldering them is to use this kind of part:
http://www.farnell.com/datasheets/54209.pdf
I have used few of those but I personally still prefer soldering for best reliability.
  #204   Ban this user!
Old 03-28-2012, 03:13 PM
Phoenix Contact is on a distinguished road
I'm curious @legendboy. What didn't you like about the Phoenix Contact D-sub modules?
Tags
brushless, servo drive, servodrive, step dir, torque control
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
KTK Drive GarageShop Bridgeport and Hardinge Mills 5 09-01-2006 08:43 AM
can brushless drive drive brushed motors ? max_imum2000 Servo Motors and Drives 2 02-09-2006 07:35 AM
Concerning the Drive Box Gorillakilla Xylotex 1 12-04-2005 07:37 AM
which VFD drive Karl_T General Metal Working Machines 10 12-03-2005 04:17 PM
