Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 05-27-2007, 10:10 PM
walter's Avatar
Gold Member
walter is on a distinguished road
Sanyo Denki P5 motor pinout
_
I'm in the process of wiring P5 to my Fluxeons. Here's the pinout, in case anyone needs it. PDF shows 14 encoder wires- Surplus Center servos were apparently custom made for Rockwell and differ from standard P5.
Standard 8 wire P5 is pictured below.
(Copley version is in the second PDF, so pick the one you like best..)
File Type: pdf Xenus_to_SANYO-DENKI-P3&P5-Series.pdf‎ (103.6 KB, 819 views)
Old 05-28-2007, 05:43 AM
Xerxes's Avatar
Xerxes is on a distinguished road
I think standard P5 has also 14 wires because the same cable carries also 6 hall sensor wires. There seems to be differences in wire colours though.
Wiring to fluxeon goes 1:1 with P50B05010PXKS7.pdf. Similar signal names have been used in VSD-A data sheet. Leave hall sensor unconnected and watch out not to short circuit them against each other or anything.
Old 05-28-2007, 01:06 PM
walter's Avatar
Gold Member
The PDF shows U Red, V White, W Black. My motor seem to struggle against itself when connected to pins 7, 6, 5 of the power connector. Swapping U&V returned Follow Error, output disabled. Can you confirm the wire colors on your 300W motor?
Or could it be the encoder?
Old 05-28-2007, 06:36 PM
Xerxes's Avatar
What do you mean with struggle? If it works corretly, drive starts holding position after power up. Current consumption should be small and drive or motor should not produce much heat.
I tested connecting U&V wires wrong. I got strong shaking and finally follow error.
Drives are shipped with "default" configuration for P5. So if it's wired properly, then you could even jog it from step/dir without running tuning software.
Wire colors seem to be equal for all Surplus Center P5's. At least the ones in data sheet for 100W model applies also for 300W and 1kW models that I have tested.
Old 05-29-2007, 01:26 AM
walter's Avatar
Gold Member
Thumbs up
Ok, that makes sense. It holds position and the rest is due to the PID settings.
I'm starting to really like this drive.
Old 06-26-2007, 12:04 PM
daedalus is on a distinguished road
I have 4 300w p5 motors here, got them off ebay rather then the surpluscenter deal, and the encoder wires are 8 pin not 15. I assumed that this would be exactly the same as the surplus center ones, just with single ended outputs instead of differential.
From testing it looks like these motors don't have commutation signals, only differential encoder outputs.
Does anyone know how you get the back off these motors to get at the encoder? Its sealed so the back looks to be glued in place. Im hoping that its still got an encoder with commutation, and the wiring is all that has been changed. If not im totally screwed, as i cant afford to buy another set of drives to get around this.
motors are labelled p50b07030dcs50
also just to make sure, when im looking at commutation signals from drive they should be logic high for 1/3 of the rotation, and logic low for 2/3 right?
Old 06-26-2007, 12:45 PM
Xerxes's Avatar
If it has quadrature encoder outputs, you're lucky (assuming that you have Fluxeons :). Commutation (hall sensor) signals are not needed or used by VSD-A.
Commutation signal has 50% up and 50% down during rotation just like quadrature signals have. Commutation signal has only few edges per revolution while quadrature has hundreds or thousands.
Old 06-26-2007, 01:00 PM
actually im quite unlucky, as i dont have any of your nice drives, as i was hoping to make do with some amc ones until i scraped together enough cash to upgrade.
i dont have a scope here, so my testing method is a bit creative. That said i have identified C and !C lines, so it must be wired as a differential encoder without commutation.
My choices now seem to be either find a way to get the back off and hope the encoder actually has commutation, and its just a custom wire (only one encoder listed with this range on sanyodenki, and it has commutation tracks).
That or buy 4 VSD-As now, which would be a nice solution if i had that kind of cash lying around. Also i had planned to be doing just torque control on the drives, and closing the control loop in EMC with a mesa interface board. The changeover kind of ruins that idea.
Old 06-26-2007, 04:09 PM
ok i give up, the only way im getting into these motors is with a hacksaw! managed to get a 100w apart and the encoder is not exactly modular, as it looks like you have to unsolder the lightsource to get the codewheel out. Even if i could swap encoders i have no idea how to align the commutation tracks.
Old 06-27-2007, 04:00 AM
jnhg is on a distinguished road
Some Sanyo Denki motors have a "combined" encoder/commutation output, where the commutation signals are output for about a second after power is applied to the encoder, then the outputs are switched to the encoder signals. I don't have a data sheet for those motors handy, but you should be able to google for it. It will make things clearer.
  #11   Ban this user!
Old 09-10-2007, 08:44 PM
darik is on a distinguished road
Hey Walter,
How are you powering those motors?
I'm assuming you are talking here for the 1000w sanyo motors. I have 4 of those and also planning to buy some fluxeons but I can't find any reasonable priced PSU.
P.S. We are on 220v/50 Hz here.
  #12   Ban this user!
Old 09-11-2007, 10:53 AM
Xerxes's Avatar
Darik, you probably need much less power than the sum of motor power. In average application I would reserve 300-500W continous power per motor. Use transformer based PSU because they can deliver high peak power just like motors can.
Sanyo-Denki Servo Motor Handbook & Sizing Al_The_Man Servo Motors and Drives 1 07-06-2007 09:02 AM
Help finding information on Sanyo Denki "Step Syn" IBM stepper motor Oracle_9 Stepper Motors and Drives 12 06-08-2007 01:55 PM
Sanyo Denki Help Gary D Stepper Motors and Drives 0 04-06-2007 09:17 AM
sanyo denki motor problem daedalus Servo Motors and Drives 15 02-22-2006 05:50 PM
Sanyo denki stepper motor kheri Stepper Motors and Drives 7 04-23-2005 02:08 AM
