Results 1 to 8 of 8
Thread: Drive question-
    Nov 2006
    Drive question-
    Tero-
    I am in the process of redoing an older mill. It currenty has large working servos installed on it. They are 136 volts and rated at 6.5 ft lb continious and 26.3 ft lb peak.
    Can the granite drive handle these?
    These motors also have tachometers on them, would i just leave the wires off?
    Steve
    Registered Xerxes's Avatar
    Sep 2004
    Finland
    I assume these are brush DC motors, aren't they? Do you have motor current ratings or torque constant value?
    If current range matches drive, then there should be no problem using them.
    Tachos are not needed, but incremental encoder is a must with VSD-E/XE.
    Nov 2006
    Tero
    The continious amps is 6.1 , but the peak is 90 amps
    What do you think?
    Steve
    Sep 2004
    Finland
    Hmm, the peak vs continuous torque and peak vs continuous current ratio does not match. If 6.5 ft lb is produced at 6.1A, then 26.3 ft lb should be delivered at 24.4A.
    Perhaps 90A is just a absolute maximum current before motor breaks and not meant to be driven purposely?
    Nov 2006
    That is what was on the data plate. I will try to find more informtion about the motor.
    The z axis has a brake, can i just use a relay to control the brake or is there a better way?
    Steve
    Sep 2004
    Finland
    If you use VSD-E in single axis mode, then it can connect brake coil to directly to drive. Brake will hold whenever drive is not controlling motor.
    Nov 2006
    Tero-
    That is the plan. I have three vsd-e s that i am planning on using. How would i set it up using the relay?
    Stevr
    Apr 2011
    If your motor brake is powered by 24v dc, and has a load of less than 800mA, you can use an external 24vdc power supply and connect to the on-board brake relay. Examine the VSD-E Manual, section 8.7, figure 13; and section 3, 'I/O characteristics'.
    If the brake exceeds those ratings I think you could then use an external relay.
    1. Question on lasering from zip drive
      By HelpNeededinWNY in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 05-06-2011, 10:39 PM
    2. Belt drive question
      By satguy in forum Linear and Rotary Motion
      Last Post: 06-11-2009, 01:28 PM
    3. Drive screw Question?
      By grahamshere in forum DIY CNC Router Table Machines
      Last Post: 10-09-2008, 01:43 AM
    4. Another belt drive question
      By AGA-man in forum Benchtop Machines
      Last Post: 11-14-2007, 04:41 PM
    5. Drive system question
      By CanopyFx in forum Mechanical Calculations/Engineering Design
      Last Post: 05-04-2005, 04:39 AM
