Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 01-15-2012, 10:48 AM
dim371 is on a distinguished road
encoder connection
Came the motor (3 phase ac servo) with broken-encoder.
Replaced by 5000 cpr incremental. - Servo (Granit Device - 160) at the slightest acceleration gives an error (encoder fault)
Dual-trace oscilloscope shows the full period of 4re sunus per revolution between any two phases.
How do I configure the encoder shaft with the shaft of the motor?
thank you
Old 01-15-2012, 11:09 AM
Al_The_Man's Avatar
AFAIK, Granite will use an incremental encoder for commutation, so it should not be necessary to align the encoder to commutation pulses if the encoder has them.
Do you get 5v TTL square wave pulses from the encoder for each channel?
Old 01-15-2012, 02:41 PM
Yes, I get 5v TTL square wave pulses A+ B+ Z+ 5000cpr
I have a picture attached for increm encoder - does not make sense ?
Thank You
Old 01-15-2012, 02:44 PM
Al_The_Man's Avatar
Where is that reference signal coming from?
Old 01-15-2012, 02:59 PM
Z encoder channel ( 1 pulse for 1 rpm)
Old 01-15-2012, 03:04 PM
Al_The_Man's Avatar
Like I said, I believe Granite does not need the marker or commutation pulses used on BLDC etc, it just uses the differential encoder signal to get a model of the motor and from then on uses the encoder as commutation.
This may be better in the Granite devices forum if you want it moved?
Old 01-15-2012, 03:12 PM
OK
moved to GD forum
THX
Old 01-15-2012, 07:26 PM
Montabelli is on a distinguished road
have you down loaded gdtool form the granite web sight? it will allow you to test the motor with the drive and tune the servo. the drive will sense the commutation requirements, and alignment of the encoder is not necessary unless you have hall effect signals on your encoder and want to use them.
Need Help!- New to old connection M.B. Vanities Machine Problems, Solutions , Wireless DNC, serial port 0 05-30-2011 02:02 AM
Broken BridgePort Encoder, Need new encoder or ServoMotor w/Encoder TNBG_LTD Want To Buy...Need help! 0 03-22-2011 09:20 PM
Need Help!- TRA 30A Connection stevenchan Mazak, Mitsubishi, Mazatrol 3 07-18-2009 03:41 PM
What is NC NO connection? mealman General Electronics Discussion 4 10-15-2007 05:59 AM
How to tell if my motor is Pulse encoder or quadrature encoder? Darc Servo Motors and Drives 0 07-22-2005 03:51 AM
