Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 01-07-2012, 07:50 AM
snoman70 is on a distinguished road
Bipolar Stepper + encoder, does Granite support?
I am in the process of learning this whole servo control thing, and I have some servo motors on another machine, but I really don't have access to them for a bit. I want to order a drive, but I want to make sure I'll have something to play with on my stepper machines. I know the VSD-XE supports steppers, but I can't find confirmation that they support steppers WITH encoder feedback...essentially just turning the stepper motor into a PM DC servo motor.
If it will, I'll place my order for a drive as soon as I get confirmation.
Thanks!
Old 01-09-2012, 06:26 AM
Xerxes's Avatar
Xerxes is on a distinguished road
The answer for controlling stepper as high pole count servo motor is yes (theoretically). However in practice this may give poor performance because:
* Steppers have high voltage constant and top speed you will get probably will be only 100 to 500 rpm
* Encoders and steppers have some linearity error which makes this setup stepper to have uneven torque sensitivity over rotation angle. Only if you're lucky you'll get very linear encoder & stepper when there's no this problem.
So in other words, its not currently recommended to use this control mode. However open loop stepper mode works ok.
What voltage for bipolar stepper 2 A, 1 Ohm ? vroemm Stepper Motors and Drives 24 09-09-2010 01:03 PM
Bipolar driver for HobbyCNC stepper CNCDevil Stepper Motors and Drives 10 08-25-2009 10:07 AM
HOBBYCNC PRO with bipolar stepper. magick_man DIY-CNC Router Table Machines 3 11-16-2006 11:04 PM
stepper drive encoder support patrick71100 Stepper Motors and Drives 14 09-17-2006 01:50 PM
Bipolar Stepper Controllers johnm99 General Electronics Discussion 2 09-08-2005 08:03 PM
