Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 01-06-2012, 11:48 AM
legendboy is on a distinguished road
Motor Inductance & Resistance (DCtool settings)
I am wondering if anybody can point me in the right direction
I am retrofitting a Boss8 servo driven bridgeport.
The only servo information I have on these motors is on the name plate. (servos are Powertron 402CNSP0S72 14.2A - 58.xA peak - 146V - 30'lb)
I am wondering if I can determine the correct DCtool settings for these motors on my own.
For the resistance value, can this be measured with a multi meter?
Is there some equation I can use to calculate the correct Inductance?
I have the motor and encoder connected to the drive and am able to run the "test". The motor does move for a second then stops. I am able to hold the motor shaft with my hand and stop it from moving during this test.
Thanks,
Corey
Old 01-07-2012, 01:29 PM
After talking with a few people it seems the best thing i can do for inductance value is look at similar motors and use the inductance they are rated for. (4-5)
I measured the resistance across the armature terminals at 1.8 ohms so that was simple enough.
Went thru my encoder wiring, found a mistake. I am lucky the mistake i made did not cause any damage. After sorting that out the tests were working as they should.
After playing around with the PID parameters and looking at the scope results i think it might be better/easier to get the servo settings tuned initially with gdtool instead of dctool.
going to flash back to standard firmware and try tonight.
I also read thru Manuals / Guides Home
Seems like the best tuning resource i have found for a newbie
Old 01-08-2012, 10:03 PM
not really expecting a reply at this point but
looking for feedback on the following
this is as close as i could get using the tuning guide:
Old 01-09-2012, 06:21 AM
Xerxes's Avatar
Xerxes is on a distinguished road
You're doing good job there! Looking motor inductance from similar size & voltage & power motor is a good way to get estimate of it. The graphs you posted shows properly tuned system.
Old 01-09-2012, 09:16 AM
Thanks for the confirmation! I appreciate it
Cheers
Motor resistance?? daz450 Stepper Motors and Drives 5 06-02-2011 04:27 PM
Series I Motor Settings ranchak Bridgeport and Hardinge Mills 0 11-24-2009 01:40 PM
Old Slo-Syn motor inductance? AndersG Stepper Motors and Drives 21 11-10-2009 12:53 AM
motor inductance? fido Stepper Motors and Drives 0 01-15-2009 11:24 AM
Motor Current Settings Davidimurray Gecko Drives 0 09-04-2006 03:34 AM
