Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 11-07-2011, 03:28 PM
Moderator
JerryFlyGuy is on a distinguished road
Connection to Drive [tuning] issues
So I came across my SPI/USB cable this weekend... [if I ever catch the little buggers who keep moving my stuff from box to box in my shop I'm gonna have him/her burnt at the stake] When I connect to my VSD-A using the GDtool [latest for VSD-A downloaded from site] I cannot get a connection.
I'm leaving the DC power disconnected and only a 18vdc logic power connected. No jumpers on the programing header, CMD cable off and I keep getting that 'check cables' error message. [I have tried it w/ the HV-DC connected the CMD cable on and every other combination I could think of with the same result]
I did some reading on here and found Tero's 'Cable checking' tool. Tried it and got a 'good cable' result.
Tried to connect again to the drive and nothing..
What else can a guy do to check this out? When I power the unit up I have a red and green flashing LED, after trying to connect from the PC the LED's are blank [not flashing or lit]. I've tried connecting w/ the Firmware jumper on to see if I could load the latest firmware [my unit's have one of the original firmwares] but no luck there either.
This is a left over drive from a lot of 4 unit's I'd bought years ago [when they first came out..] but never used [been in the original box for all these years].
I need to get this thing back up and running. I've got a long weekend coming and a large machining job which would/could run all weekend if the machine was running.. [crunch time on a large job... I know I know.. I shouldn't be making machine mods in the middle of a job. However circumstance outside my control has forced my hand..]
JerryFlyGuy
The more I know... the more I realize I don't
compact5 lathe variable spindle drive connection Buchsenmacher EMCO Lathe 0 08-08-2011 03:13 PM
Tuning new servo drive to match others k4rd HURCO 1 04-25-2010 10:34 AM
What oscilloscope for drive tuning? cut more Mazak, Mitsubishi, Mazatrol 0 03-20-2008 08:42 AM
RS232 connection issues to Milltronics Partner V Jeff S Milltronics 3 03-16-2007 06:34 AM
Trouble tuning drive mecheng10 Servo Drives 2 04-11-2006 07:28 PM
