| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
Ive had a lot of success with a large scratch build CNC lathe I built sometime ago. Ive decided to build a bigger CNC center lathe using a large center lathe as the base. Ive got some left over equipment from 4 cnc builds now... Just wondering if anyone knows which cards I need to marry up VSD XE 160 to a MESANET 5I20. I also have 2 x 7137TA and 1 x 7147S RS-422 + AOUT. I also have 2 x FANUC A06B-0128-B175 AC SERVO MOTOR a6/3000 2 x FANUC α22/2000 AC Servo Motor A06B-0147-B075 I realise I will have to change the encoders. I plan to use EMC for this build. Does anyone have any ideas or comments. Rev/s speeds required. 250nm torque on Spindle 0 Backlash Im going to couple a conedrive on a 3000RPM redcap 1m/sec on Z and X. Zero Backlash NSK using 20mm lead pitch screws. The entire weight of the bed is only 105kg. Last edited by evo4wrx; 08-27-2011 at 09:13 PM. |
| You can either change the encoders to Hall type commutation tracks or J. Elson makes a convertor board for the existing encoders. Al.
| I thought I could use Renco quadrature differential encoders. As long as they were incremental the VSD would determin the commutation required. Are there any further break out boards I require to interface the 5I20 with the VSD's. |
| I there any particular reason not to use the Fanuc encoders? Is this a frequency limitation on the VSD? Al.
| I see these B175/B075 type so I believe they are Absolute Incremental type, which could be used, but these are often 1,000,000 counts/rev, so they may be a bit high!. Too bad as most of the S motors are 2000 incremental. Al.
| That gives a far better control response than converting an (semi) analogue (PWM) velocity/torque command, into a position commond which is more or less randomly stretched out over time by the 7i76. which in turn is converted back into a velocity/torque command by the VSD again stretched out over time. If you need to use step+dir, the HostMot driver can directly generate that from EMC2 without all the time streching going on. But still PWM is better suited for Servo control. |
| I from Russia. Me interest filament winding machines | necom | CNCzone Club House | 12 | 12-05-2010 04:43 AM |
| CNC filament winder(carbon fibre) | wallygator99 | Mechanical Calculations/Engineering Design | 5 | 09-02-2007 12:46 PM |
| Filament Winder | RotorRouter | Open Source Controller Boards | 0 | 05-29-2005 07:18 PM |
