Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 07-19-2011, 02:06 PM
nicad is on a distinguished road
VSD-A Error #9 on some rapid moves
I am running 2 axis lathe with Sanyo P5 BL 300w 100v servos with VSD-A Rev2 drives. I'm using the recommended motor amperage numbers I found on here.
My PS is a very large switching regulated power supply adjustable from 40 - 200v at 14A. I currently have it set to 160v. I know it is suggested to use a linear PS, but I already had this one and it seems to be a good fit for the requirements.
I have tuned the axis with GDTool and they perform quite well- very fast accel, stiffness, and good velocity, and no errors.
However, when I control with the Smoothstepper and Mach for S/D input, I got error #9 on the drives a lot when making rapid moves. I turned the tuning way down in Mach, even to 10x slower velocity and accel, and it helped a lot but I still get error #9 every once in a while, maybe once per part cycle. I know the servos can perform way beyond this in GDTool. Any ideas why I'm getting this error with the Mach/Smoothstepper control and never in GDTool?
Ps- I checked very closely and it is for sure #9 and not error #10.
Thanks!
-Colin
Radial rapid moves around axis are jerky surfsup Fanuc 4 09-13-2011 02:39 PM
Rapid tool moves when not cutting? Fleck G-Code Programing 2 04-22-2009 01:26 AM
Newbie - torch dragging on rapid moves bad-rat-57 CNC Plasma and Waterjet Machines 3 07-10-2008 06:45 AM
Cycle Time for Rapid Moves and Tool Changes V9.1.1012 Turn jmullett Dolphin CADCAM 1 02-07-2007 04:32 AM
Rapid moves G00 dicksonhof Mach Software (ArtSoft software) 9 11-07-2006 09:21 AM
