Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 05-23-2011, 01:43 PM
fomaz is on a distinguished road
USB adaptor pinout
Hello.
I have ordered all that I could remember from granite devices, and now it seams that I must also have the USB cable to connect the drives to the PC for using the GDtool. Is the cable "special" or it is easy to make?
Any one with the wiring?
Acquiring the cable from Finland is more expensive than the cable itself I believe.
Thank you
Old 05-23-2011, 04:02 PM
bobsch's Avatar
bobsch is on a distinguished road
Here's a link to USB information, including the wiring pinouts https://secure.wikimedia.org/wikiped...USB_connectors
Bob
"Bad decisions make good stories."
Old 05-24-2011, 01:04 AM
Thank you for the reply.
I am familiar with the USB cable, but I do not know how the cable relates to the Granite VSD drive. The VSD drive have 6 pins for the USB connection and the USB standard cable have only 4 (data+, data-, +5vdc, gnd).
I did not found any documentation about the cable on the granite web site.
Thank you
Old 05-24-2011, 08:20 PM
powerr is on a distinguished road
It is a USB to TTL level serial port in a cable. This is the part number FTDI TTL-232R 5V. I bet you can find one close to you.
Old 05-25-2011, 01:09 AM
Thank you.
That was the info that I needed.
Regards
MT4 to R8 adaptor? zzambucca Benchtop Machines 5 03-05-2011 04:15 PM
ER20 to ER50 adaptor? 15mgtar Mechanical Calculations/Engineering Design 2 03-03-2010 10:57 PM
20C collet adaptor for 230MS Janos Daewoo/Doosan 0 10-24-2008 04:35 PM
MORSE TAPER TO 5C ADAPTOR smallblock General Metal Working Machines 1 08-23-2008 11:25 AM
MT2 to R-8 adaptor BarneyW Bridgeport and Hardinge Mills 3 12-28-2007 10:40 AM
