Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 03-03-2011, 12:40 PM
cobree's Avatar
cobree is on a distinguished road
Thumbs up Stepmotor test
Now the first test with stepmotor, I connected motor in Bipolar mode, A+,A-,B+,B- stated in the manual and downloaded drive config for stepmotor without encoder, adjusted PI value. Started with stepresponse in torque mode
Looking very good, fantastic work.
Next start to implement a controller with dsPIC connected to VSD-E drivers
Old 03-03-2011, 05:05 PM
Xerxes's Avatar
Xerxes is on a distinguished road
Good to hear so If you like dsPIC, then we have good news for you. Our next drive (the one with 110-230VAC input) will have used programmable dsPIC in addition to main motor control DSC. So any kind of control logic and interfacing can be programmed inside drive.
Old 03-05-2011, 06:25 AM
cobree's Avatar
Outputs new controler
For the new one will you also have the possible to control 3 more VSD, we will use 3 axis and one servo motor
Old 03-06-2011, 05:34 PM
Xerxes's Avatar
Hmm, I didn't quite understand. 3 axis machine with only one motor?
Old 03-07-2011, 10:19 AM
cobree's Avatar
Hi i have 3 step and one servomotor... of course. So if I can control 3 VSD controlling step and connected to the new driver.
Old 05-12-2011, 07:30 AM
cobree's Avatar
Running Stepmotors
Hi start testing with stepmotors and all work fine, just download the setting and start. Next is to control the system with my microcontroller and run the mechanics.
Old 05-12-2011, 08:35 AM
asuratman is on a distinguished road
Xerxes,
Your new drive is for DC servo/BLAC and bigger motor, maybe 2200 watt or 3000 watt? Thanks.
Old 05-12-2011, 11:23 AM
Xerxes's Avatar
Originally Posted by asuratman View Post
Xerxes,
Yes. Power is voltage x current so higher voltage drive easliy delivers more power.
Old 12-30-2011, 05:09 AM
cobree's Avatar
Stepmotor running
At last we have the mechanics function, and we made test with the stepmotors and VSD-E units running smoothly and the repetition really nice, thanks !
Tags
stepmotor
This is a test thread in the test forum adam.faris Test Forum 1 10-26-2008 11:21 PM
Test NateTG Test Forum 0 03-25-2008 10:59 AM
Stepmotor Identification Kresimir Stepper Motors and Drives 9 02-01-2007 12:14 PM
Mae Stepmotor Allan Holm Stepper Motors and Drives 1 10-15-2006 08:09 AM
Can someone test this one? fantasy2 G-Code Programing 10 02-19-2005 10:14 AM
