Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 11-05-2010, 10:21 AM
Lotusjohn is on a distinguished road
Wiring Clarification
From VSD-E manual
GND is the electrical 0V potential shared with power supplies and all connector pins labeled as “GND”. Connect GND to power supply 0V terminal.
FG is the ground for EMI shielding which is located in D-sub connector metal shells and D-sub connector
pins labeled as “FG”. FG and GND are electrically floating against each other but are connected by EMI
suppression capacitor inside drive.
However, the drawing on Page 16 says "negative HV connected to frame ground"
These two instructions seem to contradict one another. The drawing on page 16 connects the -HV to frame ground and the other statement connects -HV to GRD
Please clarify
John
Old 11-22-2010, 04:54 AM
Xerxes's Avatar
Xerxes is on a distinguished road
It is recommended to connect power supply negative voltage terminal to both: GND and FG.
Old 12-20-2010, 05:02 PM
nick mulder is on a distinguished road
Yeh, I wondered how the "EMI suppression capacitor inside drive" could really do anything if there is no chance for any potential difference across its terminals.
Emailed Tero (hello!) about it and got the same response you did - but still wonder about it...
Something is lacking in my electrical/electronics knowledge - I never learned much about noise/EMI - so go figure !
Old 12-27-2010, 05:20 AM
Xerxes's Avatar
Here is attached schematics of circuity between GND and FG inside drive. The purpose of capacitor is to prevent DC currents flowing on FG (i.e. ground loops). For high frequency interference this circuit is equivalent to straight wire and DC current sees only the 220k resistor.
microstep clarification stirling Gecko Drives 4 09-11-2010 12:57 PM
5 axis clarification gravyblue General CNC (Mill and Lathe) Control Software (NC) 3 03-21-2010 06:54 PM
Need clarification (Programmer vs Operator) whoknows Employment Opportunity 12 06-01-2009 01:07 PM
Clarification IQChallenged CNCzone Club House 1 06-26-2008 10:59 PM
Clarification wanted on G83 G98/99 Al_The_Man G-Code Programing 2 04-23-2007 06:30 PM
