| Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support! |
I am in the process of CNC converting a bench top mill. My plan has been to use a BLDC motor with internal hall devices. This will drive the axis through a Gilmer belt (1:4). I am planning on mounting the differential encoder directly to the ballscrew to maintain accuracy. After reading some of the other threads, I realize this may not be a good choice. Is this a stable setup ?? Would a brushed motor be a better choice ?? Is there an accuracy issue when the encoder is mounted to the motor but the motion is transmitted through a Gilmer belt ?? John |
| Hi, It's possible to mount the encoder on the screw but you must not have ANY backlash what so ever between the motor and screw as that will upset the servo-loop causing vibrations and/or need to reduce the gain in order to prevent oscillation. In other words the belt drive may not introduce any backlash what so ever. The type of motor does not matter in this context. Mounting the encoder on the screw would account for any errors caused by the belt-drive, (concentricity in of the pulleys etc) but apart from that I can't see much benefit (?). On the flip side, if you mount the encoder on the motor it gives the servo-loop 4 times as many encoder counts per unit to work with which will help making the system "stiffer". /Henrik. |
| Brushless motors | sp1nm0nkey | Taig Mills & Lathes | 29 | 06-17-2010 12:16 PM |
| Converter for Fanuc brushless encoders | jmelson | Pico Systems Motion Control Products | 5 | 10-07-2009 07:36 PM |
| where can I buy encoders w/Hall for brushless motors for reasonalbe? | springlakecnc | General CNC (Mill and Lathe) Control Software (NC) | 3 | 09-17-2007 04:05 PM |
| Brushless DC servos VS. Brushless R/C motors | sp1nm0nkey | Servo Motors and Drives | 1 | 03-07-2006 09:37 AM |
| Brushed vs Brushless encoders | bdillard | General Electronics Discussion | 8 | 01-22-2006 01:19 PM |
