Go Back   CNCzone.com-The Largest Machinist Community on the net! > Electronics > Granite Devices
Granite Devices Discuss about servo & stepper drives made by Granevices and get direct support!
Old 07-10-2010, 08:52 AM
evo4wrx is on a distinguished road
Mach 3 homing issue.
Im having a weird problem although making progress.
I have a USB smooth stepper pumping out to VSD 4 port BOB and then the two VSD-E boards.
When I set home from within mach3 90% of the time it will home at the % jog pace I set. I have soft limits setup correctly and the like and they seem to behave most of the time.
Every now and then I will click goto home or set home and the machine just runs off at full speed towards home rather than the % speed set in homing limits. Sometimes I can catch it with e-stop and the drive wont trip other times the drive will trip with follow error and I have to clear the error.
Ive run cycle testing for about 5 hours straight and haven t been able to produce a problem it seems only relating to homing. Im not using the homing cycle from the VSD board rather the homing switches are wired into the second parallel interface on the smooth stepper.
Anyone have any ideas?
Old 07-10-2010, 09:01 AM
Just encase i wasnt clear about the kind of runaway when homing this isint the full scale runaway you would see when you drop the encoder out the back of your motor. This runaway is at the same speed as the highest tuned speed of your motor.
Thanks anyone who can help....
Old 07-10-2010, 09:04 AM
ger21's Avatar
My guess is a Smoothstepper issue.
Mach issue with my mill Rich05 Mach Software (ArtSoft software) 3 11-30-2008 05:00 PM
Mach 3 homing offsets wrloveyuelin Machines running Mach Software 0 06-05-2007 12:26 PM
Fanuc tool change homing issue openforbiz Fanuc 8 01-31-2007 02:35 PM
Homing Issue Moondog Machines running Mach Software 3 07-29-2006 10:23 PM
mach homing dertsap Machines running Mach Software 2 05-11-2006 09:42 PM
