VSDE 160 BLDC problem - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
Thread: VSDE 160 BLDC problem
  1. #21
    Mar 2008
    Tried testint , it thinks the motor is a 4 pole and tells me there 2630 encoder counts.
    I can get you remote access into the machine and GDtool if you like.
    I even have a camera setup on it.
    The motor at present is not mounted. The couple is off it.
  2. #22
    Registered Xerxes's Avatar
    Sep 2004
    Finland
    You could save & email me the GDtool settings and motor specs for checking. However, from description I still suspect the encoder.
  3. #23
    Sep 2005
    Indonesia
    Hi evo4wrx,
    Just curious how big is your lathe? I am building lathe also w/GD which is on the way. I monitor this issue for info. Thanks.
  4. #24
    Mar 2008
    Its about 1.8m high...2M across.
    Hollow constuction back filled with sika granite mix for weight and dampening.
    4 axis. Turn mill to be more precise.
  5. #25
    Mar 2008
    Default Encoder problem
    I have changed the enoders to a Renco andcoder 25 serries.
    The motor is now spinning in the test with an error again.
    It suspects the motor to be a 4 pole count and is again turning 2615 counts on the encoder.
    Im basically at the same problem as I had with the US Digital Encoders.
  6. #26
    Sep 2004
    Finland
    Quote Originally Posted by evo4wrx View Post
    I'm sad to hear so. Could you email me (or post here) detailed photos of whole electrical system & wiring so I could see if there is some clear mistake? Email me at tero.kontkanen@g....devices.fi.
  7. #27
    Sep 2010
    New Zealand
    Hi There
    Im new to this and kind of been left to plow my way thru it we have purchased 6 of your drives and trying to match these up with Mach3 and also the motion king Servo motors supplied having trouble getting motors to respond
    Regards
    Tim
  8. #28
    May 2009
    that's a somewhat brief description of your problem, are you attempting a 6 axis setup? is your problem between the drives and mach3 or the motor and the drives? have you got the motors to communicate with the drives through the usb port and the granite devices set up soft ware? have you tuned the motors? how are you interfacing the drives with mach3?
  9. #29
    Sep 2010
    New Zealand
    Hi there, Thanks for the email. Sorry to be so brief when we got involved in this build we anticipated support from the agent in New Zealand but we have basically been sold the goods paid for them and been left to sort it out so im doing my best to work thru this
    This in no way is a reflection on Granite devices who are trying to help me
    the machine is large and we designed it for cutting foam plug moulds for boat building
    It has 6 drives one for Z.Y.A.B and 2 for the X Axis as the Gantry is fairly large
    The motors are 2 x 900 watts X Motion King BLDC servo drives,Y is the same but only 1 of
    Z is 1200 watt (braked ) and the rotating A is 600 Watt .the tilting Spindle head we call be is a puppy i thing around 300 watts
    My background is engineering and fabrication so this is a real struggle for me ,But a challenge to say the least
    The machine control cabinet was wired to the servo drives thru the agent here in New Zealand and the servos were at that stage befroe pluging in the extension pins all flashing purple (VSD)
    we have now pluged in the extension cords and insulated and checked and double checked the wiring as supplid with colour and pin number
    Mach 3 has been down loaded and is working on the screen we can us the pop up remote and get the count to go up on the X .Y.Z ,A screen but no go for the motors
    The drives are Flashing Red
    Green is constantly on Iluminated
    Blue is constantly on iluminated
    Just a question this may seam far out but is it possible thru the net someone can hook into this machine and help us remotely tune and do the set up
    sorry for my ignorance if it isnt that simple
    Regards
    Tim
  10. #30
    Sep 2010
    New Zealand
    Im just wondring if it was possible to set up a web cam and skype and someone could talk me thru this and as i do it they can see what im doing
  11. #31
    May 2009
    were it me, I would start by tuning the motors. you can make certain that the drive and motor are communicating that way. if the drive and motor can't be addressed through the usb cable for tuning, the problem is probably in the wiring interface between the drives and the motors. the vsd manual doesn't contain a code such as you indicate on the drives. on mine when they are ready to run they are steady blue.
    if in fact you are able to tune the motors with the GD tuning software, and you can move the motor manually from the command line in the tuning interface, then there may be a problem with the configuration of Mach3. I would suggest you download the VSDEPI manual and review allthe info there as well as the other manuals.
    I'm sorry I can't be more help than this, but I suspect the problem is in the interface between the parallel port and the drives.
  12. #32
    Sep 2010
    New Zealand
    Im going to take your advise think it jst needs to be stepped thru one the VSDE the lights are constantly on GReen and Blue and the red is flashing on all the drives
    I have spoken to Granite devices and they indicate that although we thought we had purchased a 1500 watt power suply we may have an issue there aswell
    Regards
    Tim
  13. #33
    Sep 2004
    Finland
    Hi Tim.
    There is probably nothing wrong with the 1500W power but the 12V logic supply power (judging from led blinking mode). Please try with another kind of 12V supply.
    Some supplies have long voltage rise time and that's my guess about reason for this fault.
  14. #34
    Sep 2010
    New Zealand
    Thankyou we will try this
    Regards
    Tim
  15. #35
    Sep 2010
    New Zealand
    Hi There
    Following on from our recent requests for info in relation to the setting up and interfacing of drives with servo motors
    As discused we are using Granite Devices Servo drives the system is running 5 axis although because of size of machine we have 2 drives and 2 motors driving X axis
    We call X 1
    X 2
    Y
    Z
    A
    B
    currently we have displayed on our drives and have managed to be able to tune all motors except the Z Axis which is the Larger of the Servo drives
    We note we can only tune these with Hall Sensors turned off and have discussed this wit the Granite Devices Agent here in New Zealand
    On start up phase the lights displayed flash Blue and Green All drives except the Z Axis loose the green light quickly while the Z flahes for approximatey 2 mins then goes into Red Fault
    We have upgraded the motor feed wire as the lenght is approximately 20 metres the size wire is 2.5 mm screend cable
    We would appreciate any imput to try and resolve this
    Regards
    Tim
  16. #36
    Mar 2011
    New Zealand
    Default Re: VSDE 160 BLDC problem
    Quote Originally Posted by NZCNC View Post
    Hi There
    Regards
    Tim
    hey Tim can I contact you please to talk about how you managed to solve your Granite Devices VSD and MotionKing motors , I am bench testing almost identical setup and having faulting on the drives. In the end I am curious what earthing setup you used for FG and GND and the encoder and motor cables, I suspect thats where my issue is although I have followed the manual to the best of my interpretation.
    Richard Harcourt rich@splitn2.com
