Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Gorilla CNC Machines
Gorilla CNC Machines Discuss Gorilla CNC Machines here!
Old 08-16-2009, 07:32 PM
woodman08's Avatar
woodman08 is on a distinguished road
fish plate
11x11x3/4 white pine ,5 toolpaths 3 bit changes took 34 min ,seemed to go quite fast-- 34 min
The cnc seemed to handle the speed ok and the amps were running around 7.5 on the 3/8 dia end mill
The 3d cuts are interesting
ID:	86730   Click image for larger version
Old 08-22-2009, 01:38 PM
woodman08's Avatar
procedure of doing the plate
a friend made up this video of doing the plate from scratch its easy to follow
Any tips for designing a fixture plate / tooling plate? thackman Benchtop Machines 9 12-19-2008 12:26 PM
low heat solder paste on a fish hook skipperspride Welding, Brazing, Soldering, Sealing 0 04-20-2008 07:18 PM
Need help with Brazing brone fish hooks skipperspride Welding, Brazing, Soldering, Sealing 15 01-28-2008 01:22 PM
Aluminum: flat, bar, sheet, plate, tooling plate?????????? Dan S DIY-CNC Router Table Machines 12 06-28-2007 01:48 AM
Tooling plate or sub-plate drill General CNC (Mill and Lathe) Control Software (NC) 3 02-02-2006 03:17 PM
