Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Gorilla CNC Machines
Gorilla CNC Machines Discuss Gorilla CNC Machines here!
Old 03-07-2009, 12:45 AM
woodman08's Avatar
woodman08 is on a distinguished road
unable to grease the z axis
there must be a lot of cnc machines not getting grease as I see i'm not the only person who cannot grease a bearing because the fitting is like nothing anyone has seen ,I have been told its a fitting to fit a regular gun like a needle with a 90 degree bend and you push the sharp end into the brass fitting and give it a shot,but where to get something like this.
The manufacturer (gorilla )that built my machine does not know how to grease it, amazing makes you wonder
ID:	77035   Click image for larger version
Old 03-15-2009, 09:28 PM
woodman08's Avatar
before buying general/gorilla cnc machine
make sure the manufacturer supplies you with the info or equipment fittings to grease the z axis .
i have been after gorilla for 7 months for assistance but its like talking to a wall ,now i find out that this is a overseas part SBG15SL-C bearing and they are referring me to overseas places to get the adapter ,then i'm not sure if it will work as the hole for the grease is small like a needle so its scarey to order.
Just make sure to ask before buying as documentation is very poor
Old 03-30-2009, 09:47 PM
woodman08's Avatar
after owning the machine for 14 months the manufacturer has sent me part #'s for grease and a fitting or pay them $250.00 for the fitting and some grease.Hmmmmmmmmmmmmm
The grease fitting does not fit I wonder if GM could build a car and not know how to grease it.
Old 03-31-2009, 07:40 AM
jalessi's Avatar
jalessi is on a distinguished road
Question
Woodman,
What grease fittings, are you sure GM still uses them?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-31-2009, 10:09 PM
woodman08's Avatar
that was a poor example
these car companies have asked for there own problems ,i know many dedictaced gm and ford customer who after many years of being screwed around are now going elsewhere to purchase.
The trouble with cnc machines are the cheaper easily gotten ones available to small shop owners or small users are not holding up and possibly the people making them are not holding up too.
You don't see complaints on the big industrial machines
Old 04-06-2009, 03:52 PM
woodman08's Avatar
greasing the z axis
just received a 90 degree fitting with a sharp point and it looks like with 2 people one can grease these strange fittings cost me 63.00 here at my shop
Old 04-06-2009, 06:53 PM
woodman08's Avatar
grease fitting for gorilla/general z axis grease nipples
finally after 14 months of searching i found the fitting i have a bunch here at the shop,will try it tomorow
Old 05-16-2009, 12:09 PM
Edwardo is on a distinguished road
Just out of curiousity, is it possible to change the grease fitting to a standard type more availible here, some machines ( not cnc ) that i have worked on have grease fittings in areas not very accessible, so we install short hoses with grease fittings to make it alot easier.
I looked at Gorilla over a year ago when reseaching for a plasma table but went with a different company.
Regards
EDD
Old 05-16-2009, 01:12 PM
woodman08's Avatar
grease fittings
By all means change them out as these fittings are very hard to grease even with the silly fitting that is like a needle
Where are you located
woodworking@tnt21.com
Old 05-16-2009, 08:12 PM
Hi, I am in Winnipeg... i was refering to the grease fittings on your table if it was possible to change them over to standard types. I looked at Gorilla tables a year or so ago when researching cnc plasma, but i ended up buying a Dynatorch instead, so far its been great. I plan on building a router table in the future when i get more floor space, i have been checking around and the mechmate seems like a descent machine. I enjoy watching your vids and reading your posts.
EDD
  #11   Ban this user!
Old 05-16-2009, 09:01 PM
woodman08's Avatar
grease fittings
yes i am talking about the grease fittings on the z axis ,one could change them out and put some extensions on them ,thats actually a good idea.You made the right decision on your table selection ,thanks for the comments on the utubes.
i enjoy the cnc machine just wish there was better support ,documentation and update ionformation ,
But once you own one of these it starts to come together how things can be improved.
Keep in touch
Need Help!- Unable to extrude along path PeteGallo Autodesk Software (Autocad, Inventor etc) 9 03-15-2008 03:16 PM
Oil or grease on axis?? What´s best?? jaru-eri Benchtop Machines 1 11-16-2007 02:06 PM
Grease nipples on VF0 x axis? UBRacing Haas Mills 5 07-08-2007 11:40 AM
unable to upload DXF file Al_The_Man Forum Questions or Problems 2 12-24-2004 10:24 PM
