Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Gorilla CNC Machines
Gorilla CNC Machines Discuss Gorilla CNC Machines here!
Old 02-14-2009, 09:51 PM
woodman08's Avatar
woodman08 is on a distinguished road
electric guitar rev 2
I am getting this down pat ,this one machined out well
and looks good ,used end mill 1/4 flat and end mill spiral carbide for the body cut out 16000rpm and a feed of 50
ID:	75683   Click image for larger version
ID:	75684   Click image for larger version
Old 02-16-2009, 07:42 AM
ETUDIANT is on a distinguished road
wonderfull. You Make.
Old 02-16-2009, 08:56 AM
woodman08's Avatar
guitar
thanks it was a good project utilizing layers ,i used vcarve pro (aspire) to do the layout.
I'm anxious to do more designs
Old 02-16-2009, 10:24 AM
What did you do in the program
Old 02-16-2009, 11:08 AM
woodman08's Avatar
program
I scanned in the body diagram and the cavities diagram created a pdf file then dragged the diagram over the blank piece of wood and started working at the vectors ,cleaning them up the creating 6 tool paths for the different operations,(depth and cuts)did a few test runs and then that was it .That was 3-4hours work.
But once you have this then its just a matter of gluing up another blank.
Old 02-16-2009, 01:54 PM
Kammo1 is on a distinguished road
Beautiful job bro! how easy is the Vector V Carve software to use ? I would love to start doing something like this well done keep the pictures coming
Old 02-16-2009, 05:26 PM
woodman08's Avatar
How easy ,well ...............................
I bought aspire after xmas but still have not used it and i found that vcarve pro (also aspire ) is quite easy to adapt to projects ,takes a bit of messing around but it does the job ,us humans are whats hold it back.
I am really enjoying what i have done ,the most rewarding is when you take on a project right from the idea then get it in the software produce the code and then watch the machine cut it out,flawless after a few goes.
I even record it to show friends---have i made a fortune ,no not a cent but learning all the time
woodman ontario
Old 02-16-2009, 09:42 PM
woodman08's Avatar
finished up and shipped
drilled all the holes ,sanded both sides,then the edges a bit (cnc cuts smooth 1/2 carbide end mill) and its ready for shipping less than 2 hours total (excluding the wood prep blank)(including 3 tool changes)
Very interesting project ,i'm going to try a strat next
ID:	75866   Click image for larger version
ID:	75867   Click image for larger version
Old 02-16-2009, 10:31 PM
imap is on a distinguished road
awesome
is that poplar? how do you glue it up and where do you get it?
thanks..nice project
Old 02-17-2009, 12:19 AM
woodman08's Avatar
poplar
from menonites 2x8's short pieces clamped using like veneer clamps to keep it straight,pipe clamps on the normal setup and matched the grain
  #11   Ban this user!
Old 02-22-2009, 01:09 PM
woodman08's Avatar
the raw blank form above is finished
my son finished his guitar ,looks good
ID:	76180   Click image for larger version
ID:	76181   Click image for larger version
ID:	76182   Click image for larger version
  #12   Ban this user!
Old 02-23-2009, 06:48 PM
woodman08's Avatar
pic guard maching
CNCer needed for electric guitar in Canberra ttjarrett Australia, New Zealand Club house 1 02-16-2009 08:54 AM
electric guitar body woodman08 Gorilla CNC Machines 0 01-30-2009 12:15 AM
electric guitar attempt woodman08 Gorilla CNC Machines 0 11-19-2008 09:56 PM
Building an electric guitar by hand CNCadmin Musical Instrument Design & Construction 1 06-09-2003 01:22 PM
