Results 1 to 11 of 11
Thread: control loss or glitch gorilla cnc
    Registered woodman08's Avatar
    Oct 2007
    canada
    i seem to have a problem that cannot be resolved .With the cnc machine powered up, turning on the computer (win xp) during booting the cnc machine drives the z axis down by 2.5 to 3 inches( loss of control ).
    I have changed all the settings on the parallel port ,changed the cable to the gorilla cnc and tried 3 computers ,problem does not go away and i'm afraid to use the machine as it could damage the z axis or the gantry.i have been shutdown for a week so far.
    I don't know what to do
    "http://www.youtube.com/watch?v=EngUvy3YKAE"]YouTube - control problems
    Dec 2004
    The obvious thing is to start the computer first and then turn on the cnc controls. It is "normal" for the pport to do weird things when starting up and shutting down.
    The other thing is to activate the charge pump function if available on your machine.
    The charge pump is specifically designed to prevent this kind of problem.
    Mike
    Mar 2003
    Shelby Twp, MI....USA
    Exactly what Mike said. You either need to set up a charge pump in Mach3, or do NOT power up the machine until Mach3 is running, and power down the machine before closing Mach3.
    Oct 2007
    canada
    charge pump
    I will take a look at the setting of the charge pump,but don't forget mach3 is not running ,nothing software wise is running.
    And yes i can just leave it and start the cnc after but if the computer ever glitched and rebooted(murphy's law) ,the head will be driven 2.5 to 3.0 inches which is into running into some steel damaging the gantry ,z axis or the router.
    Can you tell me where charge pump setting is (plugins?)
    Dec 2004
    If your breakout board supports the charge pump feature, then what happens is that nothing from the breakout board on down will function until it sees the charge pump signal, 20khz or something like that on the proper pin. It was designed for exactly the problems that you describe. It prevents any movement or outputs from happening untill mach3 is in full control of the machine.
    Mike
    Oct 2007
    canada
    glitch in gorilla cnc
    Well i found out that this is the way it is,if the cnc is powered up during computer boot up it will move, manufacturer says its how the parallel port works on some computers .I have tried 5 computers and they all drive the machine crazy dangerous.The gorilla people suggested a charge pump board that will stop this at a cost to be about $300.00,I'm starting to learn that this machine has no stops ,no preventions, its minimal for looking after a mistake or glitches and could cause serious costly trouble.
    I never knew this from the start and its less than 1 year old
    Mar 2003
    Oct 2007
    canada
    charge pump
    thanks --will look into this,is there much involved to tie it into the exsisting equipment
    Mar 2003
    The easiest way would probably be to add a second parallel port to your PC, using a PCI card, then add a cheap breakout board to hook it up to, like this.
    http://www.cnc4pc.com/Store/osc/prod...roducts_id=131
    Then you don't have to mess with the existing setup.
    Oct 2007
    canada
    gorilla cnc
    thanks i will get a second LPT port (pci card) and then order the add on you recommened,this sounds like a cheap fix
    Thanks for the help.
    Its difficult to know what to change as the machine came with no documnetation but i will get to understand even if i have to completely replace the electrical in the future
    Oct 2007
    canada
    2nd parallel port
    I added the second parallel port and that did the trick ,the computer can be started or turned off and the cnc machine just sits there --problem and worry soved and resolved.
    now for some stops,heat sinks and cooling.
    The electronics box needs heat sinks and cooling recommended by the gecko drive manufacturer
    1. Loss of low power control. Any suggestions
      By Strelitzia in forum General Laser Engraving & Cutting Machine Discussion
      Last Post: 11-16-2008, 03:56 PM
    2. Need Help!- y axis datum/origin loss on bridgeport interact 1 mk2 cnc mill with a TNC 151 control
      By leoncurt in forum Bridgeport and Hardinge Mills
      Last Post: 05-27-2008, 09:55 AM
    3. Need Help!- Centroid M400 Glitch
      By rdoty in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-20-2008, 02:18 PM
    4. VMC ATC Glitch?
      By One of Many in forum Bridgeport and Hardinge Mills
      Last Post: 08-02-2007, 07:58 PM
    5. Momentary Glitch or Glimpse of Great New Feature?
      By Mike Nash in forum Forum Questions or Problems
      Last Post: 05-01-2007, 09:19 PM
