Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers > Gorilla CNC Machines
Gorilla CNC Machines Discuss Gorilla CNC Machines here!
Old 09-08-2008, 04:52 PM
woodman08's Avatar
woodman08 is on a distinguished road
maching a sad face in red oak
took about 3 hours at an 8% stepover flat end mill for roughing and round ball end mill finishing,ran the router at 19000rpm feed at 60ipm--turned out very smooth
looks and feels good
sad face
ID:	66093   Click image for larger version
Old 09-08-2008, 05:16 PM
zimba43 is on a distinguished road
Hi, great piece of work, thanks for sharing.A bit too advanced for me to try yet. How long did the design take and what cad/ cam do you use?
Old 09-08-2008, 07:11 PM
woodman08's Avatar
you're wrong
thats where you're wrong its not hard and after a few plaques away you go ,cut3D software and files from
http://www.vectorclip3d.com/ and you're in business.
I'm really pleased with the results and i have a lot to learn.
Cutting 2d you can do yourself with some struggling with clipart and corel draw but 3D i could not do it but a program called art cam can help a lot
Components for CNC maching Esses CNC Wire Foam Cutter Machines 2 05-24-2006 02:28 PM
angular contact bearings face to face?? powerfade DIY-CNC Router Table Machines 2 06-19-2005 12:01 AM
Cheap CNC for maching aluminum debutis Parts for Radio Control Models 6 09-11-2004 05:38 PM
Building new maching need advice mre1000 General Electronics Discussion 2 09-06-2004 07:28 AM
maching bushings SWHITE Employment Opportunity 1 03-10-2004 10:46 PM
