Results 1 to 3 of 3
Thread: cutting out a sink opening
    Registered woodman08's Avatar
    Oct 2007
    canada
    programmed a sink cutout on a corian vanity top ,used the logitrace draw program and aspire to setup the cut
    when smooth ,better than a jigsaw and no scratches to the corian top
    It was not hard to align the cut on the top using aspire
    Mar 2003
    Shelby Twp, MI....USA
    Normally you'd cut a full elliptical hole and not the flat spot on the back, then you don't need to drill the faucet holes.
    Oct 2007
    canada
    normally
    You're right ,it wasn't required i normally just cut the hole but the top is small and 3 inch of corian to the sides so i thought the smaller the hole will leave lots of meat for rigidity.
    And it wqas my first time with corian use so i was all ears and eyes
    But it went well
  1. Auburn, AL - CNC, oxyhydrogen, Sink EDM
    By ink251 in forum Mentors & Apprentice Locator
    Last Post: 07-28-2010, 04:42 AM
  2. drill / 82 deg. c-sink combo
    By kendo in forum General Metalwork Discussion
    Last Post: 08-27-2009, 08:35 AM
  3. Need Help!- Heat Sink Too Thick For The 251?
    By Mr.Chips in forum Gecko Drives
    Last Post: 02-25-2009, 02:06 AM
  4. Kitchen sink
    By berzer in forum Moldmaking
    Last Post: 10-13-2008, 01:09 PM
  5. Sink EDM Kit
    By djauregu in forum Want To Buy...Need help!
    Last Post: 04-01-2008, 06:45 PM
