2nd run at stair tread grips
Results 1 to 1 of 1
Thread: 2nd run at stair tread grips
    Member woodman08's Avatar
    Oct 2007
    canada
    Default 2nd run at stair tread grips
    With aspire 9.010 went at the stair tread trying to cut down the machine time and also adding a reverse type cut or climb vs conventional hoping to clean
    up the cut from the V90 bit as different wood grains act differently when machined (shredded looking)
    The time has been cut a lot , but I had to do the 2 runs climb and conventional and the wood looks 99% better
    looks like these can be done at less than 10 min
    second run
    Attached Thumbnails Attached Thumbnails 2nd run at stair tread grips-one-jpg   2nd run at stair tread grips-three-jpg   2nd run at stair tread grips-two-jpg
