small stool build using fillets for tight joints
Results 1 to 1 of 1
Thread: small stool build using fillets for tight joints
    Member woodman08's Avatar
    Oct 2007
    canada
    Default small stool build using fillets for tight joints
    Built this small stool to show how tight a square piece can fit in a hole machined out with a 1/4 end mill using
    fillets
    this shows a mortise and tenon joint using a cnc machine
    a recessed corner technique and how neat it looks after it done
    with no touch up with a small saw
    the process
    Attached Thumbnails Attached Thumbnails small stool build  using fillets for tight  joints-img_0035-jpg   small stool build  using fillets for tight  joints-img_0030-jpg   small stool build  using fillets for tight  joints-img_0038-jpg   small stool build  using fillets for tight  joints-img_0039-jpg
    small stool build  using fillets for tight  joints-img_0043-jpg
