- swimming sea turtles part 3 snd final
Sea turtles swimming -part 3 completion.
It took 5 hrs cnc time for the *.stl files on the turtles,then it was 9 hrs shop time for the base prep
driftwood cutting ,sanding ,laquering and final assembly
It looks good and feels smooth,i used 5.5 board feet of 4/4 black walnut
Even the base was a chore as i had a 22in diameter piece but only half and it was a wedge cut
so i re-sawed it and laminated it together and its 1.25 thick with 4 biscuits down the centre
thats why its more oval than round
assembled sea turtles 345 degree view
Reason: wrong photos
- You may not post replies
- You may not edit your posts
Forum Rules
