Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 01-24-2010, 12:11 PM
blasttiod is on a distinguished road
Cutting models from 20mm thick Polypropylene problems
Hi all to this great forums,
I am trying to cut 20mm thick Polypropylene on my CNC. I'm using a 2 fltued cutter running at about 28000rpm. The problem I'm is that the Polypropylene is melting and clogging the cutter as it cuts and the finished model is all rough and not smooth edges.
Where am I going wrong ?
Is it the cutter/ Speed ?
Regards
Kevin
Old 01-30-2010, 08:17 AM
student1616 is on a distinguished road
i did this before.
u need to work on speed and feed.its melting and sticking to tool means your feed is very low bcz of which tool is rubbing against the job and generating heat.
lower the spindle speed(15-18K) and increase the feed.
take a scrap sheet and do all the experiments on it.best way is trial and error.
Old 01-30-2010, 08:19 AM
ger21's Avatar
How big is the tool? And what feedrate are you using? More than likely, the 28,000 rpm is much too high.
Old 01-30-2010, 07:50 PM
Thanks for the suggestions so far.
I have since tried a single fluted upcut cutter and its working fine and leaving a good cut. The only thing is, because its single flute the finish isn't as smooth as I want. I am now looking for a twin fluted cutter to try. I am having problems locating a supplier here in New Zealand. Well one who is selling at a relistic price !!!!
Regards
Kevin
Old 02-08-2010, 03:57 AM
Cutting HDPE
Hi all,
Things have improved. I am now cutting at higher feed rates and its a lot better.
The only thing is now is the surface finish. Does anyone now how I can get a better finish. At the moment its quite ripply where the cutters been. I have tried doing the cutting then doing a final fine cut but this isnt making much difference.
Regards
Old 02-08-2010, 04:39 AM
jalessi's Avatar
jalessi is on a distinguished road
Post
Blasttiod,
Have you tried a downcut end mill?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 02-08-2010, 06:23 PM
Hi Jeff,
A downcut endmill won't be any good. I doing 2 x cuts to get through the 20mm HDPE.
Regards
Kevin
Old 02-09-2010, 10:58 AM
ger21's Avatar
Ripples are usually either due to spindle runout, or a lack of rigidity in the machine.
Old 02-09-2010, 07:10 PM
Hi All,
Just found out why I'm getting these issues.
I have the routers Gcode set to climb milling and not conventional !!!
Regards
Kevin
[IMG] code is Off
Water jet cutter cutting 2mm thick SS. alexccmeister General Metal Working Machines 1 10-14-2008 11:52 AM
cutting advice for thick steel kirby General Metalwork Discussion 6 10-15-2007 05:33 PM
Cutting thick steel plate Woodenspoke General Metalwork Discussion 25 07-11-2007 11:58 PM
cutting 1/4" thick carbon fibre acidcustom Composites, Exotic Metals etc 2 05-24-2007 12:29 AM
Cutting wax models for jewerly lpz Machine Created Art 14 04-29-2007 03:40 PM
