Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 12-30-2009, 08:08 PM
Jay C is on a distinguished road
Milling UHMW - what am I doing wrong?
I'm trying to mill some small parts from .53" thick UHMW sheet. As you can see in the photos, the finish is awful. Even in the lathe the plastic stretchs rather than cuts.
The bit is a carbide TiN coated 1/8" 2-flute. Feed on the one on the right was 26ipm at 16K RPM and a .07" DOC. I've read where people love this stuff but I am not feeling the love
I am using a vacuum clamp to hold the sheet and the gauge reads 26" Hg. the portion I'm cutting is overhanging the clamp to allow me to cut through.
Thanks,
Jay
Old 12-30-2009, 09:18 PM
A1CNC is on a distinguished road
Hi Jay,
I mill UHMW alot.
Ditch the Endmill. Go with a single flute or 2 flute cutter made for plastic. I use either an Onsrud O-flute on a micro 100 made for plastic. I frequently cut (1 flute 1/2" cutter) .25" deep 60"/min 6000 rpm.
For Uhmw you need a razor sharp cutter.
Eric
Old 12-30-2009, 09:28 PM
Yes for UHMW you need a razor sharp cutter; coated carbide does not have a really sharp edge.
As suggested a cutter intended for plastic may be the best but you can get good results with uncoated micrograin carbide cutters intended for aluminum.
In the lathe use HSS tools and sharpen them with a large top rake, something like 15 degrees or more; with UHMW you have to 'slice' it off rather than chipping it off.
Old 12-30-2009, 10:29 PM
Thanks guys. Would I see the same issue with acetal using the same bit?
Old 12-30-2009, 10:47 PM
Acetal is very different to machine than UHMW. Whereas UHMW needs a good top rake acetal can be machined with zero top rake; something like brass.
Regular new carbide tools will work quite well on acetal and the micrograin carbide tools will also work well even though they often have top rake. The important thing with acetal, and UHMW, is holding the part. They are both slippery and the helix on a milling cutter can pull them out of a vise if a heavy cut is attempted. It is best if you can clamp them down or bolt them down rathetr than relying on friction in vise jaws.
Old 12-31-2009, 05:52 AM
Another good way to hold these materials is a vacuum holddown.
I have to plane 1-1/2" thick material down to 1.3". I use a 6" dia. face-mill and take off .1" deep per pass the full 6" width and have no trouble with the material moving, unless the vac pump shuts down then things get interesting!
I Generate literally trash bags full of shreaded UHMW per job.
Also not cutting fast enough for the chips to evacuate the heat from cutting will cause the material to "swell". This makes holding dimensions on your parts interesting. Feel your part after you are done, if it is warm or hot you are not taking the heat out with the chips. Plastic grows with heat.
Eric
Old 12-31-2009, 03:25 PM
Yeah, so my router is spinning too fast, my feed is too slow, and my tool is not sharp enough.
Can I improve the situation by using the slowest speed of 10K RPM, using a single flute uncoated endmill, and changing my DOC? Should I try to take deeper cuts or lighter ones? The Onsrud are pricey and this is just a personal project so I'd like to "get by" with the end mills I have.
Old 12-31-2009, 03:45 PM
CNCRim's Avatar
HSS is your answer, cheap and work great.
Old 01-28-2010, 08:27 PM
naytep is on a distinguished road
We specialize in plastics. What most of the guys say is correct. Speed up your feed and slow down your spindle. At 10k rpm I would be running 150ipm. HSS works better most of the time. If you have to use carbide because you dont know how to sharpen a tool then use the polished aluminum inserts from Korloy. There are plenty of other manufactureres but Korloy is cheep and wear or chipping isnt an issue. I use a high positive on all plastics. Threading, turning, milling. The only time I use a 0 or negative is when i am step drilling. most plastics tend to "suck" the bit in if not. Dont take small cuts unless absolutly required, especially in UHMWPE, HDPE, PP, PE. It has tendencay to burn and stick. The heavy chip gets the heat out, and its heavy enough to weigh itself down so that it doesnt wrap.
Good Luck
Success is the ability to go from one failure to another with no loss of enthusiasm-Sir Winston Churchill
[IMG] code is Off
Need Help!- holding/milling UHMW theatrewizard Haas Mills 6 05-10-2009 11:39 PM
Milling UHMW tanky321 DIY-CNC Router Table Machines 11 03-29-2008 07:56 PM
Where to buy UHMW Breaker DIY-CNC Router Table Machines 10 02-04-2008 09:41 AM
UHMW for ACME Nut? Thinwater Linear and Rotary Motion 10 01-17-2008 10:57 AM
UHMW Polyethylene Eric Nelson CNCzone Club House 2 01-26-2005 04:15 PM
