Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 10-08-2009, 11:04 AM
stormi is on a distinguished road
Bavelloni ALPA 450/4 N
Hi, I could really use some help with this mashine.
I stopped the machine while it was changing tools and the head of machine left standing in that position. After I started again I couldn't do anything... So I switched to manual work and and move the head... tool dropped down (tool is free and OK) BUT When I wanted to start it again machine refused, and I got an error message: !!tool ejector open!! , Now when I wanted to turn back to automatic work I get an error that the tool is ejected.
I tried to manually put the tool back, but it doesn't work. In the user manual, the solution for this problem is blank. Please help.
Old 10-10-2009, 04:56 AM
cyntanada is on a distinguished road
Smile
Hi
The error message shows that you triggle the senors that in the left side near the spindle.One of this sensor is cheching the tool inside or not.And the other one is checking the ejector open or not.Normally,you can solve by checking the sensors.If need more help ,let me know.
Old 10-12-2009, 11:55 AM
JEST's Avatar
JEST is on a distinguished road
Use MDI function to tell the controller there is no tool. The problem is you manually removed the tool. The sensor indicated there is no tool, the controller remembers the tool being in place. Once you manually removed the tool, you triggered a protective software loop.
Let us know if this solved your problem.
Old 10-13-2009, 07:17 AM
Problem solved.
Thank you both for replying.
The machine is working now, but it started to work on it's own the next day. I tried restarting, it didn't do anything, but when I left it turned off for a few hours, problem solved on it's own. If this problem happens again I will try your advice. Thanks again.
Old 02-03-2010, 11:16 PM
uncled66 is on a distinguished road
Talking Tool Ejector Open error message
Hey, I just had this same issue. When you manually remove the tool, check the hydraulic gauge at the top of the spindle. Watch this gauge and press the tool release button. It should move. If it does not move to zero, press the tool release button a second time. The gauge should move to zero at this point. Return to the control panel, clear the error and power the axes and you should at that point be good to go.
Old 02-04-2010, 09:14 AM
Hi all
It's good place to discuss the problem on the work here.I have a another problem, now.
I replaced the spindle belt in June.But it were out very fast on top side. Do you guys have this problem before ? How to align the spindle pulley and motor pulley ? I have some pics that shows the break belt .Pls have a check,thanks .
Old 03-11-2010, 08:30 AM
Black Sheep is on a distinguished road
Wink Belt
I think is not a problem of position.
I tink you get a short life of your belt becaues is too tight.
laso clen the two pulley are very rusty and this is not good.
Anuyway the belt is the same of original or you buy one similar?
The belt must matche perfectly the tooth of the two pulley otherwise get damage in short time.
If i remenber well the belt mst be SYNCROFLEX.
Old 06-01-2010, 08:12 AM
stonecoldcnc's Avatar
stonecoldcnc is on a distinguished road
Your belt also appears to be very dry. When I was working on a Bavelloni EGAR the technician once told me to put grease on the belt which I did about every 3 month. I never had to change the belt in the 3 years I have been using that machine.
http://stonecoldcnc.com
http://stonecoldcnc.com -> Over 1600 FREE DXF templates for sink, basin and lavatory cut outs for Granite and Marble countertops
Old 06-01-2010, 07:27 PM
But the belt won't slip ,if the grease on it ? .
How do you position the glass on table when you're going to edge the glass?
I always have a bad position on glass edge .
Old 06-03-2010, 07:56 AM
The belt never slipped in the 3 years I was running the machine and I never had to change it.
I'm working with stone and can not answer your glass questions but perhaps you could explain what you mean by "How do you position the glass on table..." and we here may be able to help you.
  #11   Ban this user!
Old 09-25-2011, 03:53 AM
zsoca is on a distinguished road
Please give me some help!
I have an Alpa 450/4N. I changed the belt of the spindle motor. It's an original belt from the bavelloni. After the changing I can't start the machine, because of the spindle motor thermal protection fault. I chacked the tight of the belt and I think it's good. I can move the spindle without any power and its rotating easily. Before the belt changing this error isn't came up.
  #12   Ban this user!
Old 09-25-2011, 05:10 PM
Hi szoca
have you checked all your circuit breakers or trip switches. I'm sure changing the belt alone wouldn't have causes the trip switches to trigger, there must have been something else happened.
[IMG] code is Off
Needed software for Z.Bavelloni Alpa/100 CNC aealaa Glass, Plastic and Stone 12 03-24-2012 03:52 PM
z bavelloni egar 320 tsjim Glass, Plastic and Stone 23 09-26-2011 08:44 AM
bavelloni marktill Glass, Plastic and Stone 5 09-25-2010 09:52 AM
EasyCad Z. Bavelloni cbieger General CAM Discussion 4 12-01-2009 07:44 PM
Bavelloni Egar320T JSandSO General CAM Discussion 5 07-13-2005 11:19 AM
