Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 09-16-2009, 06:46 AM
tchill is on a distinguished road
cutting PP and ABS
First post - What's the best method to cut Polypropylene and ABS sheets & rods down to suitable size for milling parts?
I have been using a band saw with a fine cut blade to make blanks with pretty poor results - melting, gumming up, etc.
Any suggestions would be appreciated.
[IMG] code is Off
oxy gasoline cutting torch - oPetrol cutting torch denniswang Product Announcements & Manufacturer News 6 02-20-2010 04:23 PM
Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine stephaniehamer Laser Engraving & Cutting Machines 5 06-29-2009 03:37 PM
Can Watr jet cutting and laser cutting make endmills obsolete? slashmaster Benchtop Machines 24 06-18-2009 04:07 PM
I need help about cutting heads which apply to apparel pattern cutting machine sheepgrass Mechanical Calculations/Engineering Design 0 05-12-2006 01:09 PM
