Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 07-24-2009, 02:49 AM
slavkok is on a distinguished road
POM-C POM-H Thermal expansion? Backlash?
Hello...
I'm just finishing my CNC. See at http://www.cnczone.com/forums/showthread.php?t=84773
And now I'm hit the problem. As my workshop is in attic there are big temperature change. I have Acetal nuts and work great when all is cold. As machine run the temperature rise and in PM time the temperature rise in workshop. At start there is (now) 20 deg/C in the morning and afternoon is aprox 30 deg/C. The nut heat's up aprox 15 deg/C over ambient temperature.
As I search what can be problem for excessive backlash in my machine I find that I doesn't have nut from Delrin but I have nut made from POM-C - the other type of acetal.
So I check property of both and find that my has 9.0 and Delrin 8.5 as thermal expansion coeficient.
As unit say x 10-5 Deg/K
So if I have 30 degre/K swing of temperature My nut 20mm in diameter will expand ?
9.0 x 10-5 x 30 = 0.027
multiplied by diameter 20 x 0.027= 0.54mm?
Is that true that nut wil expand for 0.54mm if temperature increase for 30 deg/K ???
Slavko.
[IMG] code is Off
Thermal Expansion!!!!! dalworth HURCO 22 06-07-2010 02:07 PM
thermal expansion and contraction ? ACME General Metalwork Discussion 5 06-26-2007 01:44 AM
Thermal Expansion mikie DIY-CNC Router Table Machines 2 11-21-2005 08:45 AM
Thermal expansion and accuracy in huge machines? Splint Mechanical Calculations/Engineering Design 13 09-01-2005 09:49 PM
Programmable CNC I/O expansion psevin Product Announcements & Manufacturer News 0 03-04-2004 11:49 AM
