Go Back   CNCzone.com-The Largest Machinist Community on the net! > Material Technology > Glass, Plastic and Stone
Glass, Plastic and Stone Discuss machining Glass, Plastic and Stone here.
Old 06-14-2009, 08:50 AM
einarkol is on a distinguished road
Question Problems with routerspeed !
Hi !
I hope someone can help me with this. I have a XJ-3030 engraver/router from XYZ-Tech, China. It has a handheld control unit called DSP unit.
I only use the machine to make nameplates from Rowmarks Lacquer 2ply vinyl.
I use 3,1mm (1/8") °30 cutters ranging in pointsize from 0,1mm and upto 0,5mm. The problem I have is with the smaller tipped cutters. I mostly run the router with a 0,5mm tipsize and that works fine. Clean cold cuts.
But when I use 0,1mm; 0,2mm; and 0,3mm then the cutters get warm and ruin the vinyl.
Are there not tables or perhaps books that do explain the Routers peeed in relation to the X,Y trawelling/proc. speed and also something called Speed Ratio ?
Help is appreciated greatly...
Einar Thor
Husavik
Iceland
[IMG] code is Off
C10 BOB Problems 2_many_hobbies Mach Mill 8 03-01-2009 07:11 PM
New Machine Build- PIC Problems niwatori1 General CNC (Mill and Lathe) Control Software (NC) 1 10-05-2008 01:57 PM
Newbie- problems b_rant Vacuum forming, Thermoforming Etc 1 02-08-2008 10:04 AM
Tsc problems Rawr77 Haas Mills 5 02-23-2007 11:42 AM
log on problems turmite Forum Questions or Problems 10 06-26-2006 02:34 PM
